[gdal-dev] Unusual(?) Callstack for GDAL Rasterdata Plugin
David Weiß
David.Weiss at ptvgroup.com
Tue Feb 17 05:42:06 PST 2015
Hi!
I wrote a basic rasterdata plugin for gdal using the raster driver api. It should provide custom rendered overviews in Quantum GIS, which is not working yet.
When loading the plugin in QGIS, it is displayed as VRT Format, which should not be because I never reference the VRT Dataset or anything related.
Also I noticed that the callstack when rendering an image in QGIS is far different from what I would expect:
> gdal_RNDd.dll!RNDRasterBand::IRasterIO(GDALRWFlag eRWFlag, int nXOff, int nYOff, int nXSize, int nYSize, void * pData, int nBufXSize, int nBufYSize, GDALDataType eBufType, int nPixelSpace, int nLineSpace) Line 107 gdal111.dll!GDALRasterBand::RasterIO(GDALRWFlag eRWFlag, int nXOff, int nYOff, int nXSize, int nYSize, void * pData, int nBufXSize, int nBufYSize, GDALDataType eBufType, int nPixelSpace, int nLineSpace) Line 261 gdal_RNDd.dll!RNDDataset::IRasterIO(GDALRWFlag eRWFlag, int nXOff, int nYOff, int nXSize, int nYSize, void * pData, int nBufXSize, int nBufYSize, GDALDataType eBufType, int nBandCount, int * panBandMap, int nPixelSpace, int nLineSpace, int nBandSpace) Line 124 + 0x8b bytes
gdal111.dll!GDALDataset::RasterIO(GDALRWFlag eRWFlag, int nXOff, int nYOff, int nXSize, int nYSize, void * pData, int nBufXSize, int nBufYSize, GDALDataType eBufType, int nBandCount, int * panBandMap, int nPixelSpace, int nLineSpace, int nBandSpace) Line 1758 + 0xaa bytes
gdal111.dll!GDALDatasetRasterIO(void * hDS, GDALRWFlag eRWFlag, int nXOff, int nYOff, int nXSize, int nYSize, void * pData, int nBufXSize, int nBufYSize, GDALDataType eBufType, int nBandCount, int * panBandMap, int nPixelSpace, int nLineSpace, int nBandSpace) Line 1797
gdal111.dll!GDALWarpOperation::WarpRegionToBuffer(int nDstXOff, int nDstYOff, int nDstXSize, int nDstYSize, void * pDataBuf, GDALDataType eBufDataType, int nSrcXOff, int nSrcYOff, int nSrcXSize, int nSrcYSize, double dfProgressBase, double dfProgressScale) Line 1527 + 0xe0 bytes
gdal111.dll!VRTWarpedDataset::ProcessBlock(int iBlockX, int iBlockY) Line 1180 + 0xbe bytes
gdal111.dll!VRTWarpedRasterBand::IReadBlock(int nBlockXOff, int nBlockYOff, void * pImage) Line 1288 + 0x13 bytes
gdal111.dll!GDALRasterBand::GetLockedBlockRef(int nXBlockOff, int nYBlockOff, int bJustInitialize) Line 1243 + 0x50 bytes
gdal111.dll!GDALRasterBand::IRasterIO(GDALRWFlag eRWFlag, int nXOff, int nYOff, int nXSize, int nYSize, void * pData, int nBufXSize, int nBufYSize, GDALDataType eBufType, int nPixelSpace, int nLineSpace) Line 484 + 0x1f bytes
gdal111.dll!GDALRasterIO(void * hBand, GDALRWFlag eRWFlag, int nXOff, int nYOff, int nXSize, int nYSize, void * pData, int nBufXSize, int nBufYSize, GDALDataType eBufType, int nPixelSpace, int nLineSpace) Line 288
Notice that there are VRTWarpedDataset and VRTWarpedRasterBand functions involved which I never used anywhere in my driver source.
I would expect GDALRasterBand::RasterIO (second from bottom) to call my overridden implementation of RNDRasterBand::IrasterIO (top) directly instead of GDALRasterBand::IRasterIO (third from bottom) and all the functions in between.
Here are my class definitions for reference:
class RNDDataset : public GDALDataset
friend class RNDRasterBand;
public:
virtual ~RNDDataset ();
virtual CPLErr GetGeoTransform ( double * padfTransform );
virtual char const * GetProjectionRef();
static int Identify ( GDALOpenInfo * openInfo );
static GDALDataset * Open ( GDALOpenInfo * openInfo );
protected:
RNDDataset ();
virtual CPLErr IRasterIO ( GDALRWFlag eRWFlag,
int nBandCount, int *panBandMap,
int nPixelSpace, int nLineSpace, int nBandSpace );
class RNDRasterBand : public GDALRasterBand
friend class RNDDataset;
public:
virtual ~RNDRasterBand ();
virtual GDALRasterBand * GetOverview ( int a_iOverview );
virtual int GetOverviewCount ();
virtual int HasArbitraryOverviews();
protected:
RNDRasterBand ( RNDDataset * const a_poDS, int const a_nBand, GDALColorInterp const a_eColorInterp, int const a_iOverview );
virtual CPLErr IReadBlock ( int a_nBlockXOff, int a_nBlockYOff, void * a_pImage );
int nPixelSpace, int nLineSpace );
Any advise what I'm missing?
Thank you,
David
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150217/27373d51/attachment-0001.html>
