[gdal-dev] Patch to improve libjpeg compatibility on gdal 1.11
David Weiß David.Weiss at ptvgroup.com
Wed Feb 18 02:04:32 PST 2015
Hey Even,
> Where I'm confused now is that I don't need any patch in the 1.11 branch to
> compile against 9a...
> The releavant extract of the output of g++ -E on libjpeg_io.cpp is {{{ # 309
> "/home/even/install-jpeg-9a/include/jmorecfg.h"
> typedef int boolean;
> so it doesn't use at all the "typedef enum { FALSE = 0, TRUE = 1 } boolean;"
> thing.
Maybe GCC doesn't because of line 307:
	#if defined FALSE || defined TRUE || defined QGLOBAL_H
But MSVC fails to have one of these defined and thus uses the else-case:
	#else
Should have mentioned that the problem occurred building with MS VS 2010.
Blessings,
David
