[gdal-dev] compiling MrSID plugin
Moritz Lennert mlennert at club.worldonline.be
Fri Feb 20 03:16:55 PST 2015
On 19/02/15 19:57, Even Rouault wrote:
> Le jeudi 19 février 2015 18:43:06, Moritz Lennert a écrit :
>> Hi,
>> I do'nt know if this is more an issue for DebianGIS, but I have the
>> feeling it is an upstream issue, so I'm posting it here. Please redirect
>> me if you think I'm wrong.
>> I'm trying to activate MrSID support for GDAL.
>> I downloaded and unpacked MrSID_DSDK-9.1.0.4045-linux.x86-64.gcc44.
>> Then I ran the following on a Debian testing machine:
>> apt-get source gdal
>> cd gdal-1.10.1+dfsg/
>> debian/rules gdal-mrsid (which AFAIU basically just creates
>> libgdal-mrsid-1.10.1.tar.gz and copies it to the directory above the
>> GDAL source directory)
>> cd ../
>> tar xvzf libgdal-mrsid-1.10.1.tar.gz
>> cd libgdal-mrsid-1.10.1/
>> chmod +x configure
>> ./configure --with-gdal=/usr/bin/gdal-config
>> --with-mrsid=/home/mlennert/SRC/MrSID_DSDK-9.1.0.4045-linux.x86-64.gcc44/Ra
>> ster_DSDK --with-jp2mrsid=no
>> make
>> sudo make install
>> I do not get any error message, but when I run
>> gdalinfo --formats | grep -i sid
>> the MrSID format is not listed.
>> I ran ldd on the plugin .so installed in /usr/lib/gdalplugin
>> and saw that it couldn't find libltidsdk.so.
>> So I set
>> export
>> LD_LIBRARY_PATH=/home/mlennert/SRC/MrSID_DSDK-9.1.0.4045-linux.x86-64.gcc44
>> /Raster_DSDK/lib/
>> and now ldd could find the library, but MrSID is still not listed
>> amongst the available formats.
> Moritz,
> If once you've set LD_LIBRARY_PATH, ldd doesn't report any unfound library,
> then you could check if GDAL_DRIVER_PATH is defined and make point it to
> /usr/lib/gdalplugin (although that path should be hardcoded in the GDAL
> library by default)
Setting GDAL_DRIVER_PATH did the trick. Thanks for the hint !
Before adding this info to the wiki as Jeff suggested, I think we should
investigate why this path is not set by default as you say.
In gcore/gdaldrivermanager.cpp I read:
"There are a few rules for the driver path.  If the GDAL_DRIVER_PATH
environment variable it set, it is taken to be a list of directories to
search separated by colons on UNIX, or semi-colons on Windows.
Otherwise the /usr/local/lib/gdalplugins directory, and (if known) the
lib/gdalplugins subdirectory of the gdal home directory are searched on
UNIX and $(BINDIR)\gdalplugins on Windows."
So, /usr/lib/gdalplugins (which is where the plugin gets installed by
default using the process I explained) does not seem to be in the list
of hardcoded paths. So, maybe '/usr/lib/gdalplugins' could be added to
the search path ? It does seem a fairly standard path...
>> - The SDK contains libgeos.so files but in a version that seems older
>> than the one in Debian Jessie. Could that be a source of conflict that
>> keeps GDAL from recognizing the plugin ?
> Hum, that might cause problem, or not, but I assume they would appear later
> with crashes or nasty behaviour when actually reading a raster. But that
> shouldn't prevent the plugin from being used.
I'll look out for that. A first reading into QGIS did not show any problems.
Moritz
