[gdal-dev] gdaltindex produces absolute paths
Pedro Venâncio
pedrongvenancio at gmail.com
Fri Feb 20 07:36:34 PST 2015
Some time ago I opened this bug report (http://hub.qgis.org/issues/11428),
because I thought it was a problem of the implementation of gdaltindex in
QGIS, but now I see that it isn't, because it also happens at the command
line.
If I put the command line in the folder where the raster files are located
[0], gdaltindex works well, ie, with -write_absolute_path option, absolute
paths are saved in the attribute table, and without -write_absolute_path
option are saved only the names of files.
But if I reference the input raster files with the absolute paths [1] (for
example, when files are in different folders), the -write_absolute_path
option has no influence, because absolute paths are always recorded in the
attribute table.
This is the desired behavior, or is it a bug?
I'm using gdal 1.11.2 (OSGeo4W), in Windows.
Thank you very much!
Best regards,
Pedro Venâncio
[0] D:\test\2013\tiff> gdaltindex -f "ESRI Shapefile"
tile_index_processing_2.shp 171_2_52.tif 171_2_42.tif
[1] D:\> gdaltindex -f "ESRI Shapefile"
D:\test\2013\tiff\tile_index_processing_3.shp
D:\test\2013\tiff\171_2_52.tif D:\test\2013\171_2_42.tif
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150220/086cee09/attachment.html>
