[gdal-dev] compiling MrSID plugin
Even Rouault
even.rouault at spatialys.com
Fri Feb 20 09:08:24 PST 2015
Le vendredi 20 février 2015 12:16:55, Moritz Lennert a écrit :
> On 19/02/15 19:57, Even Rouault wrote:
> > Le jeudi 19 février 2015 18:43:06, Moritz Lennert a écrit :
> >> Hi,
> >> I do'nt know if this is more an issue for DebianGIS, but I have the
> >> feeling it is an upstream issue, so I'm posting it here. Please redirect
> >> me if you think I'm wrong.
> >> I'm trying to activate MrSID support for GDAL.
> >> I downloaded and unpacked MrSID_DSDK-9.1.0.4045-linux.x86-64.gcc44.
> >> Then I ran the following on a Debian testing machine:
> >> apt-get source gdal
> >> cd gdal-1.10.1+dfsg/
> >> debian/rules gdal-mrsid (which AFAIU basically just creates
> >> libgdal-mrsid-1.10.1.tar.gz and copies it to the directory above the
> >> GDAL source directory)
> >> cd ../
> >> tar xvzf libgdal-mrsid-1.10.1.tar.gz
> >> cd libgdal-mrsid-1.10.1/
> >> chmod +x configure
> >> ./configure --with-gdal=/usr/bin/gdal-config
> >> --with-mrsid=/home/mlennert/SRC/MrSID_DSDK-9.1.0.4045-linux.x86-64.gcc44
> >> /Ra ster_DSDK --with-jp2mrsid=no
> >> make
> >> sudo make install
> >> I do not get any error message, but when I run
> >> gdalinfo --formats | grep -i sid
> >> the MrSID format is not listed.
> >> I ran ldd on the plugin .so installed in /usr/lib/gdalplugin
> >> and saw that it couldn't find libltidsdk.so.
> >> So I set
> >> export
> >> LD_LIBRARY_PATH=/home/mlennert/SRC/MrSID_DSDK-9.1.0.4045-linux.x86-64.gc
> >> c44 /Raster_DSDK/lib/
> >> and now ldd could find the library, but MrSID is still not listed
> >> amongst the available formats.
> > Moritz,
> > If once you've set LD_LIBRARY_PATH, ldd doesn't report any unfound
> > library, then you could check if GDAL_DRIVER_PATH is defined and make
> > point it to /usr/lib/gdalplugin (although that path should be hardcoded
> > in the GDAL library by default)
> Setting GDAL_DRIVER_PATH did the trick. Thanks for the hint !
> Before adding this info to the wiki as Jeff suggested, I think we should
> investigate why this path is not set by default as you say.
> In gcore/gdaldrivermanager.cpp I read:
> "There are a few rules for the driver path. If the GDAL_DRIVER_PATH
> environment variable it set, it is taken to be a list of directories to
> search separated by colons on UNIX, or semi-colons on Windows.
> Otherwise the /usr/local/lib/gdalplugins directory, and (if known) the
> lib/gdalplugins subdirectory of the gdal home directory are searched on
> UNIX and $(BINDIR)\gdalplugins on Windows."
> So, /usr/lib/gdalplugins (which is where the plugin gets installed by
> default using the process I explained) does not seem to be in the list
> of hardcoded paths. So, maybe '/usr/lib/gdalplugins' could be added to
> the search path ? It does seem a fairly standard path...
There's this snippet of code as well:
#ifdef GDAL_PREFIX
papszSearchPath = CSLAddString( papszSearchPath,
#ifdef MACOSX_FRAMEWORK
GDAL_PREFIX "/PlugIns");
#else
GDAL_PREFIX "/lib/gdalplugins" );
#endif
If you look at port/cpl_config.h, you'll see a #define GDAL_PREFIX with the
installation prefix, so for example /usr if you ran ./configure --prefix=/usr,
which makes /usr/lib/gdalplugins to be searched.
http://www.spatialys.com
