[gdal-dev] Question about ogr2ogr utility
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Sun Feb 22 11:46:52 PST 2015
Tomer <tomerlieber <at> gmail.com> writes:
> Hey,
> I use ogr2ogr vector utility in order to extract features which intersects a
> given extent.
> I found the "-spat" option which gets extent (2 points) as parameters, but i
> want to use a file path as parameter.
> Is there any way to do it?
What would GDAL find at the end of the file path? A shapefile or some simple
text file or what? Can you give an example?
-Jukka Rahkonen-
