[gdal-dev] invalid byte sequence for encoding "UTF8": 0xc309
Even Rouault
even.rouault at spatialys.com
Mon Feb 23 03:58:11 PST 2015
Le lundi 23 février 2015 11:36:33, Martin Landa a écrit :
> Hi Even,
> 2015-02-23 11:29 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
> > Fixed by http://trac.osgeo.org/gdal/changeset/28539
> > I'm not sure if people relied on the implicit truncation done by the COPY
> > code path, but for now it is better do disable it as it was wrong for
> > UTF-8 characters.
> thanks, I can confirm that solves this problem. Are you planning to
> backport to 1.11 branch?
The direct backport wasn't possible since the code had been refactored and
people could likely depend on truncation for non-UTF8 content.
So I have finally fixed the truncation to work. There was embryonic code, but
wrong/subobtimal, in the PGDump driver.
Should now be completely fixed in 1.11 and trunk per
http://trac.osgeo.org/gdal/ticket/5854
> Martin
http://www.spatialys.com
