[gdal-dev] misssing field width information when getting OGRLayer form filegdb
Rebecca wxx114 at 163.com
Thu Jan 8 23:47:25 PST 2015
Even
  only the field which type is string has width attribute, so you mean it's
impossible to get field width by OGRFieldDefn::GetWidth() function. Then it
is impossiable to convert vector data from filegdb to shp/mif accurately,
because the field width in filegdb is zero, then the output layer field
width will be 254.
View this message in context: http://osgeo-org.1560.x6.nabble.com/misssing-field-width-information-when-getting-OGRLayer-form-filegdb-tp5180487p5180723.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
