[gdal-dev] upper/Lower case filenames in VPF (DNC)
Malm Paul paul.malm at saabgroup.com
Tue Jan 13 02:18:31 PST 2015
is it possible to add the use CPLFormCIFilename() in the reading of DNC charts, since the casing often mismatches in references to files and actual filenames. This is a problem in LINUX.
I think this method is used for this.
Thanks,
Paul
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150113/0762b9fb/attachment.html>
