[gdal-dev] gdal_translate and multithreading
Pierre Soille
pierre.soille at jrc.ec.europa.eu
Wed Jan 14 01:11:21 PST 2015
Hello,
while translating a vrt file into a tif file with gdal_translate, I
noticed thanks to htop utility that gdal_translate is using
multithreading (typicallay 4 threads). I fail to find any multithreading
option for gdal_translate (contrary to gdal_warp that has a multi option
and where the number of threads can be set with -wo "NUM_THREADS=x").
Is there any possibility to prevent gdal_translate from multithreading?
Setting the global environment variable OMP_NUM_THREADS to 1 does not
help. I had a quick look to gdal_translate.cpp but did not find any
explicit reference to multithreading.
This behaviour of gdal_translate is an issue in case of distributed
computing. Indeed, cluster nodes with many cores are spending most of
their time with kernel time to serve a number of threads largely
exceeding the number of CPUs.
Any hint on how to solve this problem will be greatly appreciated.
Cheers,
Pierre
Pierre Soille
EC Joint Research Centre
Ispra, Italy
