[gdal-dev] Cropping a raster by a polygon - only nodata outside polygon wanted
mathieu mathieu.rajerison at gmail.com
Wed Jan 14 03:54:55 PST 2015
Is there a simple way to find one or several pixel value none of the bands
use ?
Mathieu
2015-01-14 12:06 GMT+01:00 Even Rouault-2 [via OSGeo.org] <
ml-node+s1560n5181443h90 at n6.nabble.com>:
> Selon mathieu <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5181443&i=0>>:
> > The problem is that I don't know want an alpha channel because some of
> my
> > users work on MapInfo and MapInfo doesn't deal with alpha channels..
> Really ??? Tell them to use QGIS instead. It does support alpha channel.
> Otherwise try to find a nodata value that isn't a valid pixel value. But
> I'd
> note that the nodata support in TIFF is a GDAL extended TIFF tag, so I
> wouldn't
> be surprised if MapInfo doesn't support it either.
> > 2015-01-14 11:39 GMT+01:00 Even Rouault-2 [via OSGeo.org] <
> > [hidden email] <http:///user/SendEmail.jtp?type=node&node=5181443&i=1>>:
> > > Mathieu,
> > > If 0 is a valid value at some locations of your raster, then you
> cannot
> > > use it
> > > as the nodata value. Use an alpha band instead for example by using
> > > -dstalpha
> > > instead of -dstnodata 0
> > > Even
> > > > Hello,
> > > > I crop a 3 band raster by a polygon with the following formula :
> > > > /gdalwarp -of GTiff -cutline polygon.shp -cl polygon input.tif
> > > output.tif
> > > > But pixels outside my polygon are assigned the 0 value. I'd like
> them to
> > > > have nodata
> > > > If I put the -dstnodata 0 option :
> > > output.tif
> > > > -dstnodata 0/, all the pixels in each of the 3 bands that contain
> the 0
> > > > value will be turned to nodata, even if they are contained in my
> > > polygon.
> > > > Hence, 127 0 222 will become 127 nodata 222
> > > > or 0 127 222 will become nodata 127 222
> > > > How to put the nodata value only outside my polygon ?
> > > > Thanks a lot in advance !
> > > > Mathieu
> > > > View this message in context:
> http://osgeo-org.1560.x6.nabble.com/Cropping-a-raster-by-a-polygon-only-nodata-outside-polygon-wanted-tp5181426.html
> > > > Sent from the GDAL - Dev mailing list archive at Nabble.com.
> > > > _______________________________________________
> > > > gdal-dev mailing list
> > > > [hidden email] <
> http:///user/SendEmail.jtp?type=node&node=5181432&i=0>
> > > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > > Spatialys - Geospatial professional services
> > > http://www.spatialys.com
> > > [hidden email] <http:///user/SendEmail.jtp?type=node&node=5181432&i=1>
> > >  If you reply to this email, your message will be added to the
> discussion
> > > below:
> http://osgeo-org.1560.x6.nabble.com/Cropping-a-raster-by-a-polygon-only-nodata-outside-polygon-wanted-tp5181426p5181432.html
> > >  To unsubscribe from Cropping a raster by a polygon - only nodata
> outside
> > > polygon wanted, click here
> > > NAML
> http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> http://osgeo-org.1560.x6.nabble.com/Cropping-a-raster-by-a-polygon-only-nodata-outside-polygon-wanted-tp5181426p5181437.html
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5181443&i=2>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Cropping-a-raster-by-a-polygon-only-nodata-outside-polygon-wanted-tp5181426p5181443.html
>  To unsubscribe from Cropping a raster by a polygon - only nodata outside
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5181426&code=bWF0aGlldS5yYWplcmlzb25AZ21haWwuY29tfDUxODE0MjZ8NTczODc4NDU1>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Cropping-a-raster-by-a-polygon-only-nodata-outside-polygon-wanted-tp5181426p5181453.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150114/ceb187cb/attachment.html>
