[gdal-dev] Compiling gdal 1.11.1 on ubuntu 14.10
Zoltan Szecsei
zoltans at geograph.co.za
Thu Jan 15 23:45:00 PST 2015
I compiled QGIS 2.7 successfully on ubuntu 14.10, and then noticed that
it had gdal 1.10, so I downloaded the source for gdal 1.11.1 and
compiled it.
The trouble is that running gdalinfo --version still gives me the 1.10
version.
Can anyone spot my deliberate error?
This is a new system for experimenting with, so I am able to nuke it and
start again by reloading ubuntu if need be.
My goal is to fiddle with QGIS dev, python dev, mapserver and postgis.
I'd like GRASS and OTB as well, plus all the "normal" dependencies
like gdal, ogr, proj.....
(So if someone has a recipe for the correct installation sequence so
that all the dependencies work out with their correct versions, please
post it on this list.)
Thanks & regards,
Zoltan
*So, to the current status:*
*#before make install:*
geograph at gs01:~$ which gdalinfo
/usr/bin/gdalinfo
*#after make install:* (note the different location)
/usr/local/bin/gdalinfo
*# So howcome?:*
geograph at gs01:~$ */usr/bin/gdalinfo* --version
GDAL *1.10.1*, released 2013/08/26
geograph at gs01:~$
geograph at gs01:~$ */usr/local/bin/gdalinfo* --version
geograph at gs01:~$
*Just before sending this email I did:
which gdalbuildvrt
/usr/local/bin/gdalbuildvrt
gdalbuildvrt --version
ERROR 1: gdalbuildvrt was compiled against GDAL 1.11.1 but current
library version is 1.10
*I then got into synaptic and removed gdal-bin and python-gdal but _not
libgdal-dev and libgdal1h_ (all ver 1.10) as the last one would have
removed grass and a bunch of other stuff, including postgre 9.4 and
postgis, which I want.
The above is after running sudo make install:*
geograph at gs01:~/dev/cpp/gdal-1.11.1$ sudo make install
[sudo] password for geograph:
(cd port; make)
make[1]: Entering directory '/home/geograph/dev/cpp/gdal-1.11.1/port'
make[1]: Nothing to be done for 'default'.
make[1]: Leaving directory '/home/geograph/dev/cpp/gdal-1.11.1/port'
(cd gcore; make)
make[1]: Entering directory '/home/geograph/dev/cpp/gdal-1.11.1/gcore'
make[1]: Leaving directory '/home/geograph/dev/cpp/gdal-1.11.1/gcore'
(cd alg; make)
make[1]: Entering directory '/home/geograph/dev/cpp/gdal-1.11.1/alg'
*etc etc etc**(and then the last few lines of the make install follow):*
libtool: install: /home/geograph/dev/cpp/gdal-1.11.1/install-sh -c
.libs/ogrtindex /usr/local/bin/ogrtindex
.libs/ogrlineref /usr/local/bin/ogrlineref
.libs/testepsg /usr/local/bin/testepsg
.libs/gdalbuildvrt /usr/local/bin/gdalbuildvrt
/bin/bash /home/geograph/dev/cpp/gdal-1.11.1/libtool --mode=install
/home/geograph/dev/cpp/gdal-1.11.1/install-sh -c gdal-config-inst
/usr/local/bin/gdal-config
gdal-config-inst /usr/local/bin/gdal-config
make[1]: Leaving directory '/home/geograph/dev/cpp/gdal-1.11.1/apps'
for f in LICENSE.TXT data/*.* ; do
/home/geograph/dev/cpp/gdal-1.11.1/install-sh -c -m 0644 $f
/usr/local/share/gdal ; done
/bin/bash /home/geograph/dev/cpp/gdal-1.11.1/libtool --mode=finish
--silent /usr/local/lib
/home/geograph/dev/cpp/gdal-1.11.1/install-sh -d
/usr/local/lib/pkgconfig
/home/geograph/dev/cpp/gdal-1.11.1/install-sh -c -m 0644 gdal.pc
/usr/local/lib/pkgconfig/gdal.pc
geograph at gs01:~/dev/cpp/gdal-1.11.1$ which gdalinfo
geograph at gs01:~/dev/cpp/gdal-1.11.1$ gdalinfo --version
GDAL 1.10.1, released 2013/08/26
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax: +27-86-6115323 www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150116/df56fbc4/attachment.html>
