[gdal-dev] Call for discusson on RFC 31 - OGR 64bit Integer Fields and FIDs
Even Rouault
even.rouault at spatialys.com
Fri Jan 23 07:17:33 PST 2015
This is a call for discussion on revisiting the existing RFC 31 - OGR 64bit
Integer Fields and FIDs, initiated by Frank in 2010 and that I've extended.
http://trac.osgeo.org/gdal/wiki/rfc31_ogr_64
Below the summary :
This RFC addresses steps to upgrade OGR to support 64bit integer fields and
feature ids. Many feature data formats support wide integers, and the
inability to transform these through OGR causes increasing numbers of
problems.
A first discussion took place at http://lists.osgeo.org/pipermail/gdal-
dev/2010-November/thread.html#26883. My main remarks at that time were about
compatibility issues, but as this would go in GDAL 2.0, they are likely less
critical.
Even
http://www.spatialys.com
