[gdal-dev] RE : Re: Call for discusson on RFC 31 - OGR 64bit Integer Fields and FIDs
Even Rouault
even.rouault at spatialys.com
Sat Jan 24 05:41:50 PST 2015
Dmitriy,
The main reason for the new symbol is that if we change the return type it might cause crashing problems that are not detected at compile time if GetFID is used in a printf like function. For example
printf("%ld %s", GetFID (), str)
Even
http://www.spatialys.com
<div>-------- Message d'origine --------</div><div>De : Dmitriy Baryshnikov <bishop.dev at gmail.com> </div><div>Date :24/01/2015 14:07 (GMT+01:00) </div><div>A : gdal-dev at lists.osgeo.org </div><div>Objet : Re: [gdal-dev] Call for discusson on RFC 31 - OGR 64bit Integer
Fields and FIDs </div><div>
</div>Hi Even,
The RFC looks good. One note. May be in GDAL 2 we can use GetFID instead
GetFID64? Because we can allow some incompatibility between GDAL 1.x and
GDAL 2.x.
Best regards,
Dmitry
23.01.2015 18:17, Even Rouault пишет:
> Hi,
> This is a call for discussion on revisiting the existing RFC 31 - OGR 64bit
> Integer Fields and FIDs, initiated by Frank in 2010 and that I've extended.
> http://trac.osgeo.org/gdal/wiki/rfc31_ogr_64
> Below the summary :
> This RFC addresses steps to upgrade OGR to support 64bit integer fields and
> feature ids. Many feature data formats support wide integers, and the
> inability to transform these through OGR causes increasing numbers of
> problems.
> A first discussion took place at http://lists.osgeo.org/pipermail/gdal-
> dev/2010-November/thread.html#26883. My main remarks at that time were about
> compatibility issues, but as this would go in GDAL 2.0, they are likely less
> critical.
> Even
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150124/d9e1e0b9/attachment.html>
