[gdal-dev] No OGR formats found in my OS X universal binaries?
Sean Gillies sean at mapbox.com
Sat Jan 24 10:51:00 PST 2015
Thanks, William! I'm all straightened out now. I did indeed have a problem
getting my build system to pass quoted parts.
On Fri, Jan 23, 2015 at 7:21 PM, William Kyngesburye <woklist at kyngchaos.com>
wrote:
> You need to quote the CFLAGS, CXXFLAGS and LDFLAGS parts in the configure
> line, which also overrides whatever you may have set before running
> configure as you imply (ARCHFLAGS is meaningless, drop that):
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150124/f4e84b51/attachment-0001.html>
