[gdal-dev] Call for discusson on RFC 31 - OGR 64bit Integer Fields and FIDs
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Tue Jan 27 13:47:26 PST 2015
Even Rouault <even.rouault <at> spatialys.com> writes:
> Hi,
> This is a call for discussion on revisiting the existing RFC 31 - OGR 64bit
> Integer Fields and FIDs, initiated by Frank in 2010 and that I've extended.
> http://trac.osgeo.org/gdal/wiki/rfc31_ogr_64
+1
Looks like a huge work that you have done with everything listed in
https://github.com/rouault/gdal2/compare/rfc31_64bit.
-Jukka Rahkonen-
