[gdal-dev] Python installation can't find gdal_array.py
Jorge Arévalo jorge at cartodb.com
Wed Jan 28 09:34:44 PST 2015
Hello,
I've compiled GDAL from trunk, specifying --with-python at configure
time. I first checked numpy is correctly installed. The problem is I
couldn't import gdal_array.py by default (got ImportError: no module
named _gdal_array).
Tried
python gdal_sources/swig/python/setup.py install
Didn't work.
I finally had to define
export PYTHONPATH=$PYTHONPATH:$/usr/local/lib/python2.7/dist-packages/osgeo
to make it work. And I don't think that's the default solution, right?
Am I doing something wrong?
Environment: Ubuntu 14.10, GDAL from trunk, Python 2.7.8
Many thanks in advance,
Best regards
Jorge Arévalo
CartoDB
http://cartodb.com/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150128/fe631d60/attachment-0001.html>
