[gdal-dev] Python installation can't find gdal_array.py
Even Rouault
even.rouault at spatialys.com
Wed Jan 28 10:25:02 PST 2015
Le mercredi 28 janvier 2015 19:08:18, Jorge Arévalo a écrit :
> > Even Rouault <mailto:even.rouault at spatialys.com>
> > January 28, 2015 at 6:53 PM
> > Le mercredi 28 janvier 2015 18:51:28, Jorge Arévalo a écrit :
> >> Hi,
> >>> Even Rouault<mailto:even.rouault at spatialys.com>
> >>> January 28, 2015 at 6:44 PM
> >>> Jorge,
> >>>> I've compiled GDAL from trunk, specifying --with-python at configure
> >>>> time. I first checked numpy is correctly installed. The problem is I
> >>>> couldn't import gdal_array.py by default (got ImportError: no module
> >>>> named _gdal_array).
> >>>> Tried
> >>>> python gdal_sources/swig/python/setup.py install
> >>>> Didn't work.
> >>> "didn't work", could you be more precise ?
> >>> "python setup.py install" requires root rights since it installs in
> >>> /usr/local/lib. There's a ticket&debate if the python bindings should
> >>> honour the --prefix specified at configure time or not. Currently they
> >>> don't, and it is an annoyance for folks. Perhaps we should revert to
> >>> honour the prefix, but this was disabled at some point and nobody
> >>> remembers why...
> >> Yes, I felt the pain of python bindings don't honouring the --prefix
> >> specified... Good to know there's a debate on this.
> >> Sorry about my vague description. I just did it using sudo, for a system
> >> installation, and after that, system Python still didn't find the path.
> >> So, after
> >> sudo python gdal_sources/swig/python/setup.py install
> >> I still get the same error:
> >> ImportError: no module named _gdal_array
> > Are you sure you don't have a python-gdal package hanging somewhere ?
> > (but that would be weird it wouldn't have numpy support). Or a custom
> > python-gdal bindings installed in another location that is tried before
> > the one where you install.
> Yep. Looked for gdal packages:
> dpkg-query --show --showformat='${Package;-50}\t${Installed-Size}\n' |
> sort -k 2 -n | grep -v deinstall | awk '{printf "%.3f MB \t %s\n",
> $2/(1024), $1}' | grep gdal
> 0 found. Just installed GDAL from sources, using this line
> ./configure --with-python --without-libtool
> --with-curl=/usr/bin/curl-config
> Also looked for any existent gdal_array.py
> sudo find / -name gdal_array.py
> Just found the one in my sources tree, and the system one at
> /usr/local/lib/python2.7/dist-packages/osgeo/gdal_array.py.
> If I print sys.path from Python console, I get:
> ['', '/home/jorge', '/usr/lib/python2.7',
> '/usr/lib/python2.7/plat-x86_64-linux-gnu', '/usr/lib/python2.7/lib-tk',
> '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/PILcompat']
Trying the same with python2.6, I have the following in sys.path :
'/usr/local/lib/python2.6/dist-packages/GDAL-2.0.0-py2.6-linux-x86_64.egg'
And
'from osgeo import gdal_array' works without PYTHONPATH defined
What is the output of "python setup.py install" ? Mine for reference :
$ sudo python setup.py install
running install
running bdist_egg
running egg_info
creating GDAL.egg-info
writing GDAL.egg-info/PKG-INFO
writing top-level names to GDAL.egg-info/top_level.txt
writing dependency_links to GDAL.egg-info/dependency_links.txt
writing manifest file 'GDAL.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-x86_64/egg
running install_lib
running build_py
running build_ext
creating build/bdist.linux-x86_64
creating build/bdist.linux-x86_64/egg
copying build/lib.linux-x86_64-2.6/gdal.py -> build/bdist.linux-x86_64/egg
creating build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/gdal.py -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/_gdalconst.so -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/__init__.py -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/__init__.pyc -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/gdalconst.pyc -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/_gdal.so -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/ogr.pyc -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/gdalnumeric.py -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/_gdal_array.so -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/gdalconst.py -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/ogr.py -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/osr.pyc -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/gdal_array.py -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/gdal.pyc -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/osr.py -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/_ogr.so -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/osgeo/_osr.so -> build/bdist.linux-x86_64/egg/osgeo
copying build/lib.linux-x86_64-2.6/gdalnumeric.py -> build/bdist.linux-x86_64/egg
copying build/lib.linux-x86_64-2.6/gdalconst.py -> build/bdist.linux-x86_64/egg
copying build/lib.linux-x86_64-2.6/ogr.py -> build/bdist.linux-x86_64/egg
copying build/lib.linux-x86_64-2.6/osr.py -> build/bdist.linux-x86_64/egg
byte-compiling build/bdist.linux-x86_64/egg/gdal.py to gdal.pyc
byte-compiling build/bdist.linux-x86_64/egg/osgeo/gdalnumeric.py to gdalnumeric.pyc
byte-compiling build/bdist.linux-x86_64/egg/osgeo/gdal_array.py to gdal_array.pyc
byte-compiling build/bdist.linux-x86_64/egg/gdalnumeric.py to gdalnumeric.pyc
byte-compiling build/bdist.linux-x86_64/egg/gdalconst.py to gdalconst.pyc
byte-compiling build/bdist.linux-x86_64/egg/ogr.py to ogr.pyc
byte-compiling build/bdist.linux-x86_64/egg/osr.py to osr.pyc
creating stub loader for osgeo/_gdal.so
creating stub loader for osgeo/_gdalconst.so
creating stub loader for osgeo/_osr.so
creating stub loader for osgeo/_ogr.so
creating stub loader for osgeo/_gdal_array.so
byte-compiling build/bdist.linux-x86_64/egg/osgeo/_gdal.py to _gdal.pyc
byte-compiling build/bdist.linux-x86_64/egg/osgeo/_gdalconst.py to _gdalconst.pyc
byte-compiling build/bdist.linux-x86_64/egg/osgeo/_osr.py to _osr.pyc
byte-compiling build/bdist.linux-x86_64/egg/osgeo/_ogr.py to _ogr.pyc
byte-compiling build/bdist.linux-x86_64/egg/osgeo/_gdal_array.py to _gdal_array.pyc
creating build/bdist.linux-x86_64/egg/EGG-INFO
copying GDAL.egg-info/PKG-INFO -> build/bdist.linux-x86_64/egg/EGG-INFO
copying GDAL.egg-info/SOURCES.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
copying GDAL.egg-info/dependency_links.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
copying GDAL.egg-info/not-zip-safe -> build/bdist.linux-x86_64/egg/EGG-INFO
copying GDAL.egg-info/top_level.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
writing build/bdist.linux-x86_64/egg/EGG-INFO/native_libs.txt
creating dist
creating 'dist/GDAL-2.0.0-py2.6-linux-x86_64.egg' and adding 'build/bdist.linux-x86_64/egg' to it
removing 'build/bdist.linux-x86_64/egg' (and everything under it)
Processing GDAL-2.0.0-py2.6-linux-x86_64.egg
creating /usr/local/lib/python2.6/dist-packages/GDAL-2.0.0-py2.6-linux-x86_64.egg
Extracting GDAL-2.0.0-py2.6-linux-x86_64.egg to /usr/local/lib/python2.6/dist-packages
Adding GDAL 2.0.0 to easy-install.pth file
Installed /usr/local/lib/python2.6/dist-packages/GDAL-2.0.0-py2.6-linux-x86_64.egg
Processing dependencies for GDAL==2.0.0
Finished processing dependencies for GDAL==2.0.0
> So, /usr/local/lib/python2.7/dist-packages is included, but
> /usr/local/lib/python2.7/dist-packages/osgeo doesn't. I tried with
> And then, I get ImportError: no module named _gdal
> >>>> I finally had to define
> >>>> export
> >>>> PYTHONPATH=$PYTHONPATH:$/usr/local/lib/python2.7/dist-packages/osgeo
Should rather be PYTHONPATH=$PYTHONPATH:/usr/local/lib/python2.7/dist-packages (without the final osgeo) actually
> >>>> to make it work. And I don't think that's the default solution, right?
> >>> That's what I use since I have many GDAL versions on my machine and
> >>> must switch between them without reinstalling. For regular users not
> >>> tweaking the installation prefix, "sudo make install" should do the
> >>> right thing however.
> >> Yep, that was what I thought. But still fails after sudo make install.
> >> The only way I've found to make it work is by exporting PYTHONPATH
> >> Best regards,
> >> Jorge
> >>>> Am I doing something wrong?
> >>>> Environment: Ubuntu 14.10, GDAL from trunk, Python 2.7.8
> >>> Even
> > Jorge,
> >> named _gdal_array).
> >> Tried
> >> Didn't work.
> > remembers why...
> >> export
> > That's what I use since I have many GDAL versions on my machine and must
> > switch between them without reinstalling. For regular users not tweaking
> > the installation prefix, "sudo make install" should do the right thing
> > however.
> > Even
http://www.spatialys.com
