[gdal-dev] Setting encoding using Python API
Even Rouault even.rouault at spatialys.com
Fri Jan 30 01:39:58 PST 2015
Le vendredi 30 janvier 2015 10:37:30, Roger André a écrit :
> Hi All,
> Curious how I go about specifying the equivalent of "-lco ENCODING=UTF-8"
> when using the Python API to write out shapefiles with OGR?
Roger,
sure: taken from autotest suite:
shape_ds.CreateLayer('test_utf_cut', geom_type = ogr.wkbPoint, \
	options = ['ENCODING=UTF-8'])
Even
http://www.spatialys.com
