[gdal-dev] compiling mongodb driver???
Even Rouault even.rouault at spatialys.com
Mon Jul 6 05:31:44 PDT 2015
Le lundi 06 juillet 2015 14:12:11, kusala nine a écrit :
> I'm still struggling with compiling in the mongo driver to version 2.1 of
> the source. I compile the mongocxx driver (scons --prefix=<dir>
> --sharelibraries=yes install) and then use the build folder to point the
> gdal build at the mongoclient.so but, even after a successful ./configure I
> get the messages below. Looks to me like I'm missing symbols which should
> be defined somewhere else - is libmongoclient.so the only thing external to
> gdal that I need to link? Are the boost libraries included in the
> mongo-cxx-driver? I have the rest of boost on the system and the driver
> compiled fine but the final linking is where it falls over. all help
> gratefully received...
I've added recently a "build instructions" section at the end of
http://gdal.org/drv_mongodb.html
From your errros, I'd say it looks like if libmongoclient.so itself is not
found (there might be an issue with boost libs too, but you'll see it once the
issue with libmongoclient is fixed). You should specify  --with-mongocxx to the
installation prefix of the mongoclient. So <dir> in your example.
Is there a libmongoclient.so in /home/ubuntu/gdal/mongo/mongo-cxx-
driver/b2/lib ? Is  /home/ubuntu/gdal/mongo/mongo-cxx-driver/b2 the <dir> of
your scons command line ?
> Jon.
> /bin/bash /home/ubuntu/gdal/gdal/gdal/libtool --mode=link       g++
>  gdalinfo.lo commonutils.lo  /home/ubuntu/gdal/gdal/gdal/libgdal.la -o
> gdalinfo
> libtool: link: g++ .libs/gdalinfo.o .libs/commonutils.o -o .libs/gdalinfo
>  /home/ubuntu/gdal/gdal/gdal/.libs/libgdal.so -L/usr/lib
> -L/home/ubuntu/gdal/mongo/mongo-cxx-driver/b2/lib -lgeos_c
> /usr/lib/x86_64-linux-gnu/libsqlite3.so -lodbc -lodbcinst
> /usr/lib/x86_64-linux-gnu/libexpat.so /usr/lib/libxerces-c.so -lnsl
> -ljasper -lnetcdf /usr/lib/libhdf5.so -lm /usr/lib/libmfhdfalt.so
> /usr/lib/libdfalt.so /usr/lib/x86_64-linux-gnu/libgif.so -ljpeg -lpng -lpq
> -lz -lpthread -lrt -ldl -lpcre /usr/lib/x86_64-linux-gnu/libcurl-gnutls.so
> -lxml2 -lmongoclient -lboost_system -lboost_thread -lboost_regex
> /home/ubuntu/gdal/gdal/gdal/.libs/libgdal.so: undefined reference to
> `mongo::client::Options::setFIPSMode(bool)'
> `mongo::client::Options::setSSLPEMKeyFile(std::basic_string<char,
> std::char_traits<char>, std::allocator<char> > const&)'
> `mongo::client::Options::setSSLCRLFile(std::basic_string<char,
> `mongo::client::shutdown()'
> `mongo::BSONObjBuilderValueStream::endField(mongo::StringData const&)'
> `mongo::client::initialize(mongo::client::Options const&)'
> `mongo::verifyFailed(char const*, char const*, unsigned int)'
> `mongo::BulkOperationBuilder::execute(mongo::WriteConcern const*,
> mongo::WriteResult*)'
> `mongo::DBClientCursor::nextSafe()'
> `mongo::BSONElement::Array() const'
> `mongo::msgasserted(int, std::basic_string<char, std::char_traits<char>,
> `mongo::BulkOperationBuilder::~BulkOperationBuilder()'
> `mongo::BSONObjBuilder::appendElements(mongo::BSONObj)'
> `mongo::BSONObjBuilder::appendDate(mongo::StringData const&,
> mongo::Date_t)' /home/ubuntu/gdal/gdal/gdal/.libs/libgdal.so: undefined
> reference to
> `mongo::BulkOperationBuilder::BulkOperationBuilder(mongo::DBClientBase*,
> std::basic_string<char, std::char_traits<char>, std::allocator<char> >
> const&, bool)'
> `mongo::BSONObjBuilder::appendElementsUnique(mongo::BSONObj)'
> `mongo::BSONObjBuilderValueStream::BSONObjBuilderValueStream(mongo::BSONObj
> Builder*)' /home/ubuntu/gdal/gdal/gdal/.libs/libgdal.so: undefined
> reference to `mongo::client::Options::setSSLCAFile(std::basic_string<char,
> `mongo::WriteResult::hasErrors() const'
> `mongo::client::Options::setSSLPEMKeyPassword(std::basic_string<char,
> `mongo::client::Options::setSSLMode(mongo::client::Options::SSLModes)'
> `mongo::DBClientConnection::DBClientConnection(bool,
> mongo::DBClientReplicaSet*, double)'
> `mongo::client::Options::setSSLAllowInvalidCertificates(bool)'
> `mongo::DBClientWithCommands::auth(mongo::BSONObj const&)'
> `boost::filesystem2::detail::status_api(std::basic_string<char,
> std::char_traits<char>, std::allocator<char> > const&,
> boost::system::error_code&)'
> `mongo::DBClientWithCommands::findAndRemove(mongo::StringData const&,
> mongo::BSONObj const&, mongo::BSONObj const&, mongo::BSONObj const&)'
> `mongo::DBClientWithCommands::getCollectionNames(std::basic_string<char,
> std::char_traits<char>, std::allocator<char> > const&, mongo::BSONObj
> const&)'
> `mongo::BSONObjBuilderValueStream::operator<<(mongo::BSONElement const&)'
> `mongo::IndexSpec::IndexSpec()'
> `mongo::client::Options::setSSLAllowInvalidHostnames(bool)'
> `mongo::WriteResult::WriteResult()'
> `mongo::client::Options::Options()'
> `mongo::HostAndPort::HostAndPort(mongo::StringData const&)'
> `mongo::Status::toString() const'
> `mongo::IndexSpec::addKeys(mongo::BSONObj const&)'
> `mongo::OID::toString() const'
> `mongo::BSONElement::Obj() const'
> `mongo::BSONObj::jsonString(mongo::JsonStringFormat, int, bool) const'
> `mongo::BulkOperationBuilder::insert(mongo::BSONObj const&)'
> `mongo::OID::init(std::basic_string<char, std::char_traits<char>,
> `mongo::invariantFailed(char const*, char const*, unsigned int)'
> collect2: ld returned 1 exit status
> make[1]: *** [gdalinfo] Error 1
> make[1]: Leaving directory `/home/ubuntu/gdal/gdal/gdal/apps'
> make: *** [apps-target] Error 2
> On Wed, Jun 24, 2015 at 4:28 PM, kusala nine <kusala9 at googlemail.com> wrote:
> > great thanks - I'll have a go. many thanks for the pointer.
> > J
> > On Wed, Jun 24, 2015 at 4:23 PM, Even Rouault
> > <even.rouault at spatialys.com>
> > wrote:
> >> Jon,
> >> It is in the development version (2.1.0dev), not 2.0.0. The website
> >> displays
> >> the doc of the dev version.
> >> On Unix, you must use the following configure options:
> >>   --with-mongocxx=ARG        Include MongoCXX support (ARG=Path, yes or
> >> no)
> >>   --with-boost-lib-path=ARG   Path to boost libraries for mongocxx
> >>   client
> >> On Windows, look at the directions in nmake.opt (search for MONGO)
> >> Even
> >> > Hi - has anyone got any pointers on compiling the mongodb drivers into
> >> the
> >> > latest 2.0.0 version of gdal. I've been watching for a while and the
> >> > new 2.0.0 page has a table saying that mongo is included but not
> >> > compiled
> >> in by
> >> > default. I've downloaded the libraries and compiled them from the link
> >> on
> >> > the gdal "vector formats" page but no idea how to integrate the mongo
> >> > library into the rest of the ogr tools. I know there was a bit of
> >> traffic
> >> > about this a year ago but couldn't find anything more up to date. All
> >> help
> >> > gratefully received!....
> >> > thanks
> >> > Jon.(P).
> >> Spatialys - Geospatial professional services
> >> http://www.spatialys.com
