[gdal-dev] Determining GDAL WMS download limit?
Andre Vautour
andre.vautour at caris.com
Tue Jul 7 07:22:31 PDT 2015
Looks like that server only has 7 levels for that satellite layer:
http://mt.google.com/vt/lyrs=s&x=0&y=0&z=7
http://mt.google.com/vt/lyrs=s&x=0&y=0&z=8
The terrain and map layers have 22 levels:
http://mt.google.com/vt/lyrs=t&x=0&y=0&z=22
http://mt.google.com/vt/lyrs=t&x=0&y=0&z=23
http://mt.google.com/vt/lyrs=m&x=0&y=0&z=22
http://mt.google.com/vt/lyrs=m&x=0&y=0&z=23
So, you'd have to change the TileLevel element:
<TileLevel>7</TileLevel>
That smaller size probably ended up querying tile levels < 8 which is
why it worked.
André
On 2015-07-07 11:02, Carl Godkin wrote:
> Hi,
> I would like to know if there's a way to determine if a GDAL WMS download
> is going to work or not from the information in the local description
> file.
> I'm using C++ code to do this, but can illustrate my question with a
> gdal_translate
> command. This command fails:
> gdal_translate -outsize 6700 6700 \
> -srcwin 144884562 100729336 178000 178687 \
> frmt_wms_googlemaps_tms.xml \
> out.tif
> Input file size is 268435456, 268435456
> 0...10...20...30...40...50...60...70ERROR 1: GDALWMS: Unable to
> download block 35372, 24624.
> URL: http://mt.google.com/vt/lyrs=s&x=35372&y=24624&z=16
> HTTP status code: 404, error: (null).
> ERROR 1: frmt_wms_googlemaps_tms.xml, band 1: IReadBlock failed at X
> offset 35372, Y offset 24624
> but if I change the -outsize arguments to 6500 and 6500, it works fine.
> I am perfectly willing to accept the limitations of what's available,
> but can I tell where that limit will be?
> The service file is from the frmts/wms directory with the "Satellite"
> ServerURL line active instead of the "Map" line.
> Notes:
> 1. Curiously, the default "Map" ServerURL works to much higher
> resolution (at least 15000) which makes me
> think that the answer to my question will be "no" since the service
> description files are otherwise identical!
> 2. The map area above is Italy, but I see the same sort of behavior
> around the world.
> I am using GDAL 1.11.2 on Windows7 x64, but see the same behavior on
> Linux RHEL5 64-bit as well.
> Thank you very much for any insight,
> carl
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150707/63121ae9/attachment.html>
