[gdal-dev] Call for discussion on RFC 59: GDAL/OGR utilities as a library
faza mahamood fazamhd at gmail.com
Thu Jul 9 11:32:31 PDT 2015
This is a call for discussion on RFC 59: GDAL/OGR utilities as a library.
https://trac.osgeo.org/gdal/wiki/rfc59_utilities_as_a_library
Summary:
This RFC defines new function for each GDAL utility. The new utility
functions can be used to work on in-memory datasets. The utility code is
modified to call the new function. This RFC gives a general frame and
principles, demonstrated with gdalinfo, but aimed at being extended with
other utilities.
Regards,
Faza
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150710/c582140b/attachment.html>
