[gdal-dev] ogr2ogr 2.0 PG driver problem
michele_zanolli at comune.trento.it michele_zanolli at comune.trento.it
Wed Jul 15 02:42:50 PDT 2015
Hi all,
I recently installed GDAL 2.0 and this is my issue:
if I take a simple shp (or csv file) and then
ogr2ogr -f PostgreSQL "PG:host=localhost user=myuser schemas=myschema" mylayer -nln mylayer
The layer is successfully imported in the DB and in the right schema, but I read:
ERROR 1: PQconnectdb failed: invalid connection option "schemas"
ERROR 1: Couldn't establish a database connection
If i use the -overwrite option, no errors are printed.
michele
