[gdal-dev] Gdal_calc.py with more than 26 input files
Even Rouault even.rouault at spatialys.com
Thu Jul 16 16:13:34 PDT 2015
On Thursday 16 July 2015 20:38:44 Jukka Rahkonen wrote:
> Hi,
> Have a look at this gis.stackexchange question:
> http://gis.stackexchange.com/questions/149006/does-gdal-calc-only-support-26
> -input-raster-files-at-a-time
> So, what users can do if they have more than 26 input files?
Hi Jukka,
The easiest way is the one suggested in of the gis.stackexchange questions:
extend the AlphaList array with new letters (I think you could put any string
actually that doesn't conflict with other options)
But when you have more than 26 input files, it is dubious that you really want
to individually identify them with a particular letter/name. As in one of the
examples, you likely just want to apply a global operation on them, like sum,
mean, .... So they would be better passed as a lis
t so as to be able to build a 3 dimension numpy array, so you can do things
like:
--input foo.tif bar.tif ... --calc "rasters.mean(axis=0)"
And you could also still reference a particular raster with rasters[i] syntax
(To be clear: the above is not something currently available)
Even
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
