[gdal-dev] Why is saving an array to ENVI file format using SaveArray so slow?
mike c
mikec7200 at hotmail.com
Fri Jul 24 01:12:59 PDT 2015
Dear GDAL Developers
I’m finding that when
saving a relatively small array (shape =
128,4000,128 ie 128 band x 4000 lines x
128 columns of float data = 256Mb total) to a ENVI file format using the call:
gdalnumeric.SaveArray(img,strf_out,'ENVI')
performance is extremely slow (~260 seconds). When I save the same array to Geotif format using;
gdalnumeric.SaveArray(img,strf_out,'GTIFF')
the operation
takes ~24 seconds which is much more
acceptable.
I’m currently
using gdal version 1.11.1 .
My question to
the forum is then -why is there such a
large discrepancy between the performance of the two operations and is there a way
to improve the performance when writing an array to an ENVI file format?
I have tried changing
the GDAL Cache options but performance doesn’t seem to alter. When profiling the code which saves the array
to GeoTIFF format I get the output contained in the attached file timing_savearray_GTIFF.txt. When profiling the code which saves the array
to ENVI format I get the output contained in the attached file timing_savearray_ENVI.txt
I would like to
save the data to ENVI file format. Your
thoughts on this matter would be appreciated.
Thanks
Regards
mike
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150724/83c5eb1f/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150724/83c5eb1f/attachment.txt>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150724/83c5eb1f/attachment-0001.txt>
