[gdal-dev] decimal truncation when gdal_translate/gdalwarp
Ramiro Marco Figuera
r.marcofiguera at jacobs-university.de
Fri Jul 24 04:09:12 PDT 2015
Trent,
Thanks a lot for the quick answer. I am using the img files so, I guess
I will have to apply the offset correction. When using gdal_translate I
already use "gdal_translate -ot Float32 -unscale in_16bit.lbl
out_32bit.tif". I think the problem might be when I use gdal_translate
-of XYZ in.tif out.xyz to get a readable file for my code. I am afraid
that the decimal truncation is happening in this step.
About the offset, Thanks for the explanation. I will apply the code to
correct this issue.
Again, thanks a lot!
Cheers,
Ramiro
On 07/23/2015 04:57 PM, Hare, Trent wrote:
> Ramiro,
> I believe all 16bit LOLA DEMs have a scale in the header of 0.5
> (they do release 32bit files also). Check to make sure the scale
> parameter exists using gdalinfo. To apply this value during conversion
> you have be explicit and specify "-ot Float32" AND "-unscale". So
> something like this.
> > gdal_translate -ot Float32 -unscale in_16bit.lbl out_32bit.tif
> If you are converting the Jpeg2000 files, and you don't see this
> scale, you also need to download the GDAL *.xml file within the LOLA
> archive and rename. They were not allow to archive with more than one
> extension (silly constraint for this day-and-age). For example for
> their geoJpeg2000s:
> first rename:
> > mv ldem_85n_10m_aux.xml ldem_85n_10m.jp2.aux.xml
> now convert to 32bit Tiff (please see tip below):
> -unscale ldem_85n_10m.jp2 ldem_85n_10m_32bit.tif
> example data from:
> http://pds-geosciences.wustl.edu/lro/lro-l-lola-3-rdr-v1/lrolol_1xxx/data/lola_gdr/polar/jp2
> Regards,
> Trent
> Tip: I have been warned by the LOLA team to be cautious using anything
> higher-res than 20m for polar analysis.
> P.S. Just to muddy the water for LOLA:
> Currently for LOLA PDS (*.lbl) labels, you will need to override the
> OFFSET defaults. Thus for any PDS LOLA *.lbl label to remove an
> incorrect 1 pixel shift you need to also include these command-line
> --config options:
> for gdalinfo:
> > gdalinfo --config PDS_SampleProjOffset_Shift 0.5 --config
> PDS_LineProjOffset_Shift 0.5 in.lbl out.tif
> For LOLA polar files the *center should be perfectly 0.0, 0.0
> meters* in Cartesian space
> for conversion:
> > gdal_translate -ot Float32 -unscale --config
> PDS_SampleProjOffset_Shift 0.5 --config PDS_LineProjOffset_Shift 0.5
> in.lbl out_32bit.tif
> *note: *you *don't* need to use this for the LOLA the *.jp2 files
> (with renamed *.xml file). The *.jp2 internal headers use the more
> standard Offsets in meters which are correct (not the odd PDS's scaled
> pixel-space offsets - at least odd to me).
> _History_: There are several known offset issues
> <https://trac.osgeo.org/gdal/ticket/3940> for many PDS archives. For
> GDAL's PDS support, LOLA currently has this issue for PDS labels
> (again not the *.jp2). It was recently determined that the LOLA PDS
> *.lbl Offset are *actually correct* but GDAL and ISIS3 have had a 1
> pixel PDS offset read error since they were written. This actually is
> born from a unfortunate series of events, where our initial test case,
> MOLA was (and still is) released with incorrect offsets. This PDS
> offset issue is slated to be fixed for GDAL
> <https://trac.osgeo.org/gdal/ticket/5941>. Now once this update gets
> pushed in, archives that had happened to be incorrect (but worked
> correctly, e.g. MOLA) will need to use these overrides.
> I am hoping during the transition from PDS3 to PDS4 most of these
> offset issues can be dealt with (plenty of other issues to also deal
> with for various archives though). Support for a PDS4 driver will
> start once the format solidifies. Lastly, since ISIS3 also uses
> Offsets in meters, there has never been this issue within GDAL's ISIS3
> driver.
> On Thu, Jul 23, 2015 at 2:31 AM, Ramiro Marco Figuera
> <r.marcofiguera at jacobs-university.de
> <mailto:r.marcofiguera at jacobs-university.de>> wrote:
> Hi all,
> I'm creating polar gnomonic DEMs using the LOLA DEMs as input
> files in gdal. My end product is an ascii file with X Y Z values.
> The original LOLA DEM is data type integer16 and I'm trying to
> transform it to a float32. I use -ot Float32 in gdal_translate and
> -wt Float32 in gdalwarp to be sure that the data type doesn't
> changes during the process. The problem is that when I open my XYZ
> file, the Z column has only 3 decimal positions. Is there anything
> I'm doing wrong or am I completely wrong trying to do this?
> Cheers
> Ramiro
> Department of Physics and Earth Sciences
> Jacobs University Bremen
> Campus Ring 1, 28759 Bremen, Germany
> Office: Research III, Room 99b
> Tel: +49 (0)421 200 3226
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150724/29fe6a20/attachment.html>
