[gdal-dev] gdal_translate and gdal_gdaladdo to create tiled pyrimidal tiffs: grey?
Even Rouault even.rouault at spatialys.com
Wed Jun 3 02:34:29 PDT 2015
Le mercredi 03 juin 2015 11:15:16, Koen2704 a écrit :
> Dear community
> I am trying to create tiled pyrimidal tifs through GDAL library tools:
> First I do: gdal_translate test.tif tiled_test.tif -b 1 -b 2 -b 3 -co
> COMPRESS=JPEG -co PHOTOMETRIC=RGB,
Note: the resulting dataset will not be tiled if you don't specify -co
TILED=YES
> then I do: gdal_gdaladdo --config
> COMPRESS_OVERVIEW JPEG --config PHOTOMETRIC_OVERVIEW RGB --config
> INTERLEAVE_OVERVIEW PIXEL -ro tiled_test.tif 2 4 8 16
> In the end I get a nice tiled pyrimidal tif, but it is greyscale?! How do I
> keep the colors?!
That's surprising. Are you sure the viewer is using overviews properly ? You
could try "gdal_translate tiled_test.tif.ovr ovr2.tif" and display ovr2.tif.
If it looks OK, then it's likely an issue with the viewer. If it is greyscale
then there's a strange issue for which sharing your dataset would be good for
further investigation.
> http://osgeo-org.1560.x6.nabble.com/gdal-translate-and-gdal-gdaladdo-to-cr
> eate-tiled-pyrimidal-tiffs-grey-tp5208842.html Sent from the GDAL - Dev
> mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
