[gdal-dev] OGRGeometry copy constructor
Simon Hege
simonhege at hotmail.com
Fri Jun 5 08:27:34 PDT 2015
Looking at the code of GDAL 2.0 (but also 1.x), I noticed that the OGRGeometry class (and the derived classes) do not respects the Rule of 3 : there is a destructor and no copy constructor or assignment operator. It seems to me that this may lead to memory leaks on OGRSpatialReference (for example when using std::vector<OGRPoint> and not std::vector<OGRPoint*>).
This is not an issue when using the C API because the clone() method is used.
Am I well understanding the API ?
Various solutions exists:
1) defines private copy constructors and assignment operators (eg. libkml does this with a macro on each class: LIBKML_DISALLOW_EVIL_CONSTRUCTORS)
2) implements these methods, and manage poSRS the same way that clone() does.
3) do nothing (and document it somewhere)
If needed I may open an issue and/or send a patch.
Best regards,
Simon HEGE
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150605/8473bf27/attachment.html>
