[gdal-dev] Validating a projection
Andre Joost
andre+joost at nurfuerspam.de
Sun Jun 7 20:56:20 PDT 2015
Am 08.06.2015 um 01:38 schrieb Doug McCorkle:
> Andre,
> I have updated the projection information with the recommended names.
> When I process GeoTIFF files with this projection everything works
> fine while all of the data is in memory and none of the Datasets in
> question are written to disk. If I write the data to disk in a
> GeoTIFF file and then try to reload the data and acquire the EPSG
> with the AutoIdentifyEPSG method I get the unsupported srs error.
The code 102039 is not an official EPSG code, but rather invented by
ESRI. That is the reason why some software depending on PROJ/GDAL does
not AutoIdentify the code number.
HTH,
André Joost
