[gdal-dev] assigning vertical datum to image files
Newcomb, Doug
doug_newcomb at fws.gov
Tue Jun 9 07:38:30 PDT 2015
Evan,
Here is the output from gdalinfo wit the expanded config.
Note the error messages on failure to load datum shift files for the
corner coordinates.
I'll upgrade to RC1 and check that again, but thought I would mention.
gdalinfo --config GTIFF_REPORT_COMPD_CS YES D05_37_30081003_20141231.tif
Driver: GTiff/GeoTIFF
Files: D05_37_30081003_20141231.tif
Size is 1000, 1000
Coordinate System is:
COMPD_CS["unknown",
PROJCS["NAD83(2011) / North Carolina (ftUS)",
GEOGCS["NAD83(2011)",
DATUM["NAD83_National_Spatial_Reference_System_2011",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","1116"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","6318"]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",36.16666666666666],
PARAMETER["standard_parallel_2",34.33333333333334],
PARAMETER["latitude_of_origin",33.75],
PARAMETER["central_meridian",-79],
PARAMETER["false_easting",2000000],
PARAMETER["false_northing",0],
UNIT["US survey foot",0.3048006096012192,
AUTHORITY["EPSG","9003"]],
AXIS["X",EAST],
AXIS["Y",NORTH],
AUTHORITY["EPSG","6543"]],
VERT_CS["NAVD88 height",
VERT_DATUM["North American Vertical Datum 1988",2005,
EXTENSION["PROJ4_GRIDS","g2012a_conus.gtx,g2012a_alaska.gtx,g2012a_guam.gtx,g2012a_hawaii.gtx,g2012a_puertorico.gtx,g2012a_samoa.gtx"],
AUTHORITY["EPSG","5103"]],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["Up",UP],
AUTHORITY["EPSG","5703"]]]
Origin = (3010000.000000000000000,805000.000000000000000)
Pixel Size = (5.000000000000000,-5.000000000000000)
Metadata:
AREA_OR_POINT=Area
DataType=Generic
Image Structure Metadata:
COMPRESSION=DEFLATE
INTERLEAVE=BAND
Corner Coordinates:
ERROR 1: failed to load datum shift file
Upper Left ( 3010000.000, 805000.000)
Lower Left ( 3010000.000, 800000.000)
Upper Right ( 3015000.000, 805000.000)
Lower Right ( 3015000.000, 800000.000)
Center ( 3012500.000, 802500.000)
Band 1 Block=1000x2 Type=Float32, ColorInterp=Gray
Description = Layer_1
Min=-3.000 Max=-3.000
Minimum=-3.000, Maximum=-3.000, Mean=-3.000, StdDev=0.000
NoData Value=-3.40282306073709653e+38
Metadata:
LAYER_TYPE=athematic
STATISTICS_COVARIANCES=0
STATISTICS_MAXIMUM=-3
STATISTICS_MEAN=-3
STATISTICS_MEDIAN=0
STATISTICS_MINIMUM=-3
STATISTICS_MODE=0
STATISTICS_SKIPFACTORX=1
STATISTICS_SKIPFACTORY=1
STATISTICS_STDDEV=0
Doug
On Tue, Jun 9, 2015 at 10:21 AM, Newcomb, Doug <doug_newcomb at fws.gov> wrote:
> Evan,
> I went back and checked. The .aux.xml sidecar files with the img files
> do not appear to have projection information.
> Doug
> On Tue, Jun 9, 2015 at 9:32 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Selon "Newcomb, Doug" <doug_newcomb at fws.gov>:
>> > Thanks!
>> > That should work in this case to build the virtual raster. I'm still
>> > curious about assigning the vertical datum to the rasters.
>> Doug,
>> I'm a bit surprised that the HFA driver reports a SRS with a VERTCS node
>> as a
>> child of the PROJCS node. I believe this is an incorrect WKT definition.
>> There
>> should rather be a COMPD_CS root note with 2 children: a PROJCS node for
>> the
>> horizontal CRS and a VERTCS node for the vertical CRS. Perhaps this SRS
>> string
>> is defined in the .aux.xml sidecar files that are apparently present ?
>> Regarding your question, there are a few EPSG codes that correspond to
>> aCOMPD_CS, for example 6349. Otherwise, GDAL allows to build a custom
>> COMPD_CS
>> with the syntax EPSG:XXXX+YYYY where XXXX is the EPSG code of the
>> horizontal SRS
>> and YYYY the EPSG code of the vertical SRS. In your case that should be
>> EPSG:6543+5703 I think
>> So you can do things like "gdal_translate in.tif out.tif -a_srs
>> EPSG:6543+5703"
>> If you read back out.tif, you will only get the horizontal SRS by
>> default. This
>> was for backward compatibility reason I think. But if you specify
>> "--config
>> GTIFF_REPORT_COMPD_CS YES" you will get the COMPD_CS.
>> Even
>> > Doug
>> > On Tue, Jun 9, 2015 at 1:48 AM, Hermann Peifer <peifer at gmx.eu> wrote:
>> > > About your initial problem:
>> > > > but gdalbuildvrt complained, informing me that
>> > > > they were not in the same projection.
>> > > What about using the below gdalbuildvrt option?
>> > > Hermann
>> > > -allow_projection_difference:
>> > > (starting with GDAL 1.7.0) When this option is specified, the utility
>> will
>> > > accept to make a VRT even if the input datasets have not the same
>> > > projection. Note: this does not mean that they will be reprojected.
>> Their
>> > > projection will just be ignored.
>> > > Source: http://www.gdal.org/gdalbuildvrt.html
>> > > On 2015-06-08 21:01, Newcomb, Doug wrote:
>> > >> Hi Folks,
>> > >> I have a directory of 783 .img format Lidar - based DEMs in the same
>> > >> projection, North Carolina State Plane Feet (2011) , NAD 83 ,
>> NVD88. I
>> > >> was going to use gdalbuildvrt to create a single virtual image for
>> the
>> > >> area, but gdalbuildvrt complained, informing me that they were not in
>> > >> A couple of quick bash scripts/commands
>> > >> for x in *.img; do gdalinfo $x >>img_info.txt;done
>> > >> and
>> > >> grep PROJCS img_info.txt|sort|uniq -c
>> > >> gives me the following:
>> > >> 437
>> PROJCS["NAD_1983_2011_StatePlane_North_Carolina_FIPS_3200_Ft_US",
>> > >> 346
>> PROJCS["NAD_1983_StatePlane_North_Carolina_FIPS_3200_Feet_2011",
>> > >> gdalinfo gives the following for each type of file ( origin section
>> > >> clipped out) :
>> > >> Driver: HFA/Erdas Imagine Images (.img)
>> > >> Files: D05_37_20878102_20141231.img
>> > >> D05_37_20878102_20141231.img.aux.xml
>> > >> Size is 1000, 1000
>> > >> GEOGCS["GCS_NAD_1983_2011",
>> > >> DATUM["NAD_1983_2011",
>> > >> SPHEROID["GRS_1980",6378137.0,298.257222101]],
>> > >> PRIMEM["Greenwich",0.0],
>> > >> UNIT["Degree",0.017453292519943295]],
>> > >> PARAMETER["False_Easting",2000000.0],
>> > >> PARAMETER["False_Northing",0.0],
>> > >> PARAMETER["Central_Meridian",-79.0],
>> > >> PARAMETER["Standard_Parallel_1",34.3333333333333],
>> > >> PARAMETER["Standard_Parallel_2",36.1666666666667],
>> > >> PARAMETER["Latitude_Of_Origin",33.75],
>> > >> UNIT["Foot_US",0.30480060960121924],
>> > >> VERTCS["NAVD_1988_Foot_US",
>> > >> VDATUM["North_American_Vertical_Datum_1988"],
>> > >> PARAMETER["Vertical_Shift",0.0],
>> > >> PARAMETER["Direction",1.0],
>> > >> UNIT["Foot_US",0.3048006096012192]]]
>> > >> Files: D05_37_20957301_20141231.img
>> > >> D05_37_20957301_20141231.img.aux.xml
>> > >> Size is 1000, 1000
>> > >> UNIT["Degree",0.0174532925199433]],
>> > >> PARAMETER["False_Easting",2000000.002616666],
>> > >> PARAMETER["Standard_Parallel_1",34.33333333333334],
>> > >> PARAMETER["Standard_Parallel_2",36.16666666666666],
>> > >> In theory, these should all be EPSG:6543, so just assigning the
>> correct
>> > >> horizontal projection/datum with the epsg code should make things
>> > >> usable. (i.e,
>> > >> gdal_translate -a_"srs epsg:6543" --config GDAL_CACHEMAX 512 -of
>> GTiff
>> > >> -co COMPRESS=DEFLATE -co PREDICTOR=3 in.img out.tif ) ( Thank you
>> for
>> > >> the EPSG:6543 projection support in GDAL 2.0!)
>> > >> However, this only assigns the horizontal infomation, how does one
>> > >> assign a vertical datum with a horizontal EPSG code?
>> > >> I see the NVD88 code in vertcs.csv , but how would I implement it in
>> the
>> > >> above command?
>> > >> Using gdal 2.0 Beta2
>> > >> Doug
>> > >> Doug Newcomb
>> > >> USFWS
>> > >> Raleigh, NC
>> > >> 919-856-4520 ext. 14 doug_newcomb at fws.gov <mailto:
>> > >> The opinions I express are my own and are not representative of the
>> > >> official policy of the U.S.Fish and Wildlife Service or Dept. of the
>> > >> Interior. Life is too short for undocumented, proprietary data
>> formats.
>> > >> _______________________________________________
>> > >> gdal-dev mailing list
>> > >> gdal-dev at lists.osgeo.org
>> > >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> > Doug Newcomb
>> > USFWS
>> > Raleigh, NC
>> formats.
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> Doug Newcomb
> USFWS
> Raleigh, NC
> Interior. Life is too short for undocumented, proprietary data formats.
Doug Newcomb
USFWS
Raleigh, NC
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150609/323e8726/attachment-0001.html>
