[gdal-dev] gdal_rasterize does not burn polygon attributes
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Thu Jun 11 04:35:14 PDT 2015
jramm <jamessramm <at> gmail.com> writes:
> I'm running gdal_rasterize, trying to make it create a new tif from
polygons, using an attribute field as the burn value. Here is my command:
> gdal_rasterize -tr 5 5 -a SOP -l test -a_nodata 0 test.shp test.tif
> I end up with an image that is all 0's. The shapefile is correct and can
be read by OGR...what am I missing?
We are not exactly lazy but the easier it is to study and reproduce the
issue the more probable it is that someone really does it. Next time try to
share a small sample of data as well.
Without having access to your data I digitized two polygons, added an
integer attribute "SOP" and inserted values "10" and "110".
I modified your command
gdal_rasterize -tr 5 5 -a SOP -l burntest -a_nodata 0 burntest.jml test.tif
I was awaiting that one polygon would be burned with value 10, the other
with 110. Quit test with gdalinfo suggests that it did happen:
gdalinfo test.tif -stats
Driver: GTiff/GeoTIFF
Files: test.tif
Size is 100, 64
Coordinate System is `'
Origin = (487.000000000000000,632.000000000000000)
Pixel Size = (5.000000000000000,-5.000000000000000)
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (     487.000,     632.000)
Lower Left  (     487.000,     312.000)
Upper Right (     987.000,     632.000)
Lower Right (     987.000,     312.000)
Center      (     737.000,     472.000)
Band 1 Block=100x10 Type=Float64, ColorInterp=Gray
  Minimum=10.000, Maximum=110.000, Mean=68.598, StdDev=49.255
  NoData Value=0
  Metadata:
    STATISTICS_MAXIMUM=110
    STATISTICS_MEAN=68.597662771285
    STATISTICS_MINIMUM=10
    STATISTICS_STDDEV=49.255255505085
Notice that datatype is Float64 which means that data range 10-110 is very
narrow when compared to full 64-bit scale.
Here is my test data in OpenJUMP JML format which is understood by GDAL 2.0.
<?xml version='1.0' encoding='UTF-8'?>
<JCSDataFile xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2000/10/XMLSchema-instance" >
<JCSGMLInputTemplate>
<CollectionElement>featureCollection</CollectionElement>
<FeatureElement>feature</FeatureElement>
<GeometryElement>geometry</GeometryElement>
<ColumnDefinitions>
     <column>
          <name>SOP</name>
          <type>INTEGER</type>
          <valueElement elementName="property" attributeName="name"
attributeValue="SOP"/>
          <valueLocation position="body"/>
     </column>
</ColumnDefinitions>
</JCSGMLInputTemplate>
<featureCollection>
     <feature>
          <geometry>
                <gml:Polygon>
                  <gml:outerBoundaryIs>
                  <gml:LinearRing>
                    <gml:coordinates>487.0,631.0
                      875.0,632.0
                      636.0,361.0
                      487.0,631.0 </gml:coordinates>
                  </gml:LinearRing>
                  </gml:outerBoundaryIs>
                </gml:Polygon>
          </geometry>
          <property name="SOP">10</property>
     </feature>
     <feature>
          <geometry>
                <gml:Polygon>
                  <gml:LinearRing>
                    <gml:coordinates>894.0,575.0
                      668.0,313.0
                      988.0,355.0
                      894.0,575.0 </gml:coordinates>
                  </gml:LinearRing>
                </gml:Polygon>
          </geometry>
          <property name="SOP">120</property>
     </feature>
     </featureCollection>
</JCSDataFile>
-Jukka Rahkonen-
