[gdal-dev] Proj4 Transformation Error 6
Jay L.
jlaura at asu.edu
Fri Jun 12 09:59:21 PDT 2015
Using GDAL 1.11.2 (Anaconda Python osgeo binstar install).
I have a WKT projection:
'PROJCS["Mercator",GEOGCS["GCS_Moon_2000",DATUM["D_Moon_2000",SPHEROID["Moon_2000_IAU_IAG",1737400.0,0.0]],PRIMEM["Reference_Meridian",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Mercator"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",180.0],PARAMETER["Standard_Parallel_1",0.0],UNIT["Meter",1.0]]'
I import this into a srs object and attempt to export to Proj4. This is
throwing:
RuntimeError: No translation for Mercator to PROJ.4 format is known.
Along the same lines, I am trying to compute pixel to latlon and the
inverse. So I need a transformation object. No problem setting that up
until:
RuntimeError: Failed to initialize PROJ.4 with `+proj=merc +lon_0=0 +k=0
+x_0=0 +y_0=0 +a=3396190 +b=3376200 +units=m +no_defs '.
Which leads me to try:
gdalsrsinfo -V '+proj=merc +lon_0=0 +k=0 +x_0=0 +y_0=0 +a=3396190
+b=3376200 +units=m +no_defs'
Validate Succeeds
PROJ.4 : '+proj=merc +lon_0=0 +k=0 +x_0=0 +y_0=0 +a=3396190 +b=3376200
+units=m +no_defs '
OGC WKT :
PROJCS["unnamed",
GEOGCS["unnamed ellipse",
DATUM["unknown",
SPHEROID["unnamed",3396190,169.894447223611]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Mercator_1SP"],
PARAMETER["central_meridian",0],
PARAMETER["scale_factor",0],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
So gdalsrsinfo is able to validate the proj4 string.
Any ideas?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150612/f015b3bb/attachment.html>
