[gdal-dev] Gdal-Grid lidar.
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Jun 12 14:18:26 PDT 2015
Hi Even,
Thank you very much. I increased the buffer to 1.5 GB (512+512+514)*1024*1024 and I can now work much much faster with gdal_grid.
Does gdal_fillnodata have the same type of variable that could speed things up? It is also slow and does not seem speeded up by the "All_CPUS".
I will use warp and the raster calculator in the future so you have more magic up your sleeve, I would appreciate it.
Cheers and thanks again.
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112 Fax: 514.381.4995
www.archeotec.ca
On Jun 5, 2015 19:13, Even Rouault <even.rouault at spatialys.com> wrote:
> Le samedi 06 juin 2015 00:18:45, Nicolas Cadieux a écrit :
> > Hi,
> > I have been using gdal_grid to interpolate LiDAR data for some time now.
> > This would be a typical command:
> > gdal_grid -l P0344_sol2004_XYZI_MTM8_CGVD28_150529 -txe 348733.0 401135.0
> > -tye 5568587.0 5773796.0 -a
> > nearest:radius1=3.0:radius2=3.0:angle=0.0:nodata=0.0 -outsize 52402.0
> > 205209.0 -of GTiff
> > H:/Nicolas/pytemp/OutPut\P0344_sol2004_XYZI_MTM8_CGVD28_150529.vrt
> > H:/Nicolas/pytemp/OutPut\P0344_sol2004_XYZI_MTM8_CGVD28_150529.tif --confi
> > g GDAL_NUM_THREADS ALL_CPUS
> > As you can see, this is a huge raster and the csv. file (Pointed with a
> > .vrt) contains over a billion points. I am trying to do this in one shot
> > to avoid boundary effects. (I know I can split this .csv file into
> > smaller bits and make this more efficient). The computer I am using has
> > 12 cores, 64BG of memory (smaller than the csv file) and a 1TB pcie solid
> > state drive. It should manage the task but it has been running for 5 days
> > with less than 10% done). I have access to a super computer with gdal if
> > all else fails.
> > This is my question. The "--config GDAL_NUM_THREADS ALL_CPUS" or "--config
> > GDAL_NUM_THREADS 12" does not seem to work with the nearest neighbor
> > algorithm. (It seem to work with the -a count command) If I use this on a
> > smaller data set, I see no difference in speed or cpu usage between using
> > the "ALL_CPUS" or not using this switch. Is this a bug or simply a
> > limitation of the nearest neighbor algorithm?
> Nicolas,
> The threading mechanism is generic for all algorithms . Add "--debug on" and
> you should see traces like "GDAL_GRID: Using 12 threads". Now, a reason for it
> not being efficient is that the work buffer used by gdalgrid (16 MB) is too small
> w.r.t to nearest speed. Hum, actually looking more closely at the code, I see
> that the quad tree to index the points will be rebuilt for each work buffer.
> This is likely the main cause of the inefficiency and why you don't see
> measurable differences between non threaded or threaded computations (since the
> building of the quadtree is not multithreaded). If you compiled from source,
> you could try changing the "const GUInt32 nDesiredBufferSize = 16*1024*1024;"
> line in apps/gdal_grid.cpp to a much higher value. A more proper solution
> would be to avoid rebuilding the quad tree for each work buffer. This is mainly
> code restructuring.
> An alternative to gdal_grid would be to use gdal_rasterize + gdal_fillnodata.
> This is usually much much faster, so you could try to check if it gives the
> results you expect.
> You could also try scipy :
> http://docs.scipy.org/doc/scipy-0.14.0/reference/generated/scipy.interpolate.griddata.html#scipy.interpolate.griddata
> Not sure how it behaves with that number of points.
> Even
> > I don't want to move this
> > to a super computer if it will not multi-thread properly.
> > Thanks,
> > Nicolas Cadieux
> > (Gdal1.11.2 downloaded with OSGEO4W 64bit install with QGIS 2.8 on windows
> > 7_64) I use GDAL from the command line not from QGIS.
> > www.archeotec.ca
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Spatialys - Geospatial professional services
> http://www.spatialys.com
