[gdal-dev] Question on WFS and encoding
Andreas Neumann
a.neumann at carto.net
Thu Jun 18 06:50:22 PDT 2015
I want to transform a WFS to Postgis, using this WFS service:
http://wms.zh.ch/NEKWMS with the layer "landwirtschaftliche-nutzungseignung"
While this works fine, there seems to be an issue with encoding. German
Umlauts are not correctly displayed after the transformation. Is there a
way to specify the encoding in ogr2ogr or with some options for WFS?
http://www.gdal.org/drv_wfs.html does not list an encoding option.
Or is it a misconfiguration of the server, if the Umlauts do not display
correctly?
Thank you for any hints!
Andreas
