[gdal-dev] Gdal-Grid lidar.
Even Rouault even.rouault at spatialys.com
Thu Jun 18 08:43:19 PDT 2015
Le mardi 16 juin 2015 19:00:45, Even Rouault a écrit :
> Le mardi 16 juin 2015 18:50:58, Nicolas Cadieux a écrit :
> > "As you're exploring new territories, I'd expect you to report how this
> > works ;-) "
> > Report no 1:
> > (Sharing how little I know but still trying to help:)
> > I have been recompiling gdal_grid with a 1 and 1.5 GB buffer instead of
> > the usual 16 mb.  (Both files created with the 1 and 1.5GB are
> > identical).
> > Increasing the buffer size makes the interpolation much faster (hour
> > instead of weeks) but there may be a possible side effect I would like to
> > share.
> > It seem that the .tiff file (84GB) is very slow to display in QGIS.  When
> > I use gdalwarp to resave this file (without actually changing the
> > projection or null zero values), I  create an identical file with the
> > same dimension and pixel resolution that is blazing fast to view in
> > QGIS.  There does not seem to be a pyramid in this new file that could
> > explain the results.
> > Is it possible that by using such a big buffer, the .tiff is not encoded
> > efficiently and that this is fixed when the file is pass through
> > gdalwarp?
> Ah, no, this is a "well known" behaviour of gdal_grid. It creates an image
> whose origin is the bottom-left of the image (instead of the upper-left
> usually). Consequently QGIS must creates a warp VRT to get a more classical
> dataset, which slow down things.
> A trick to generate directly a file with upper-left origin is to specify
> "-tye ymax ymin" (instead of "-tye ymin ymax")
> I guess this behaviour of gdal_grid should be changed as it regularly
> annoys people.
Note: I've committed yesterday in gdal trunk 2.1dev several improvements :
- the refactorization I mentionned some time ago, to avoid the quad tree to be
rebuilt each time, which makes the increasing of the buffer size less necessary
- a new algorithm, linear, which is way much much faster than any other
existing algorithm and tends to generate better results
> > Nicolas Cadieux M.Sc.
> > Les Entreprises Archéotec inc.
> > 8548, rue Saint-Denis Montréal H2P 2H2
> > Téléphone: 514.381.5112  Fax: 514.381.4995
> > www.archeotec.ca
> > On Jun 15, 2015 15:24, Even Rouault <even.rouault at spatialys.com> wrote:
> > > Le lundi 15 juin 2015 21:00:15, Nicolas Cadieux a écrit :
> > > > Thanks Even,
> > > > One last question about the buffer. Is 2GB is the max buffer size for
> > > > gdal_grid? If I select that, am I likely to run into problem with
> > > > some values?
> > > The variable is a uint32 so you could probably go up to 4 GB.
> > > > Apart from trial and error, is there a balance that should be
> > > > stuck between available computer memory (currently at 64GB), input
> > > > file size and the buffer or can I simply select a 2GB buffer?
> > > works ;-)
> > > > Merci beaucoup pour votre aide.
> > > > www.archeotec.ca
> > > > On Jun 12, 2015 17:29, Even Rouault <even.rouault at spatialys.com>
wrote:
> > > > > Le vendredi 12 juin 2015 23:18:26, Nicolas Cadieux a écrit :
> > > > > > Hi Even,
> > > > > > Thank you very much.  I increased the buffer to 1.5 GB
> > > > > > (512+512+514)*1024*1024 and I can now work much much faster with
> > > > > > gdal_grid.
> > > > > > Does gdal_fillnodata have the same type of variable that could
> > > > > > speed things up?  It is also slow and does not seem speeded up by
> > > > > > the "All_CPUS".
> > > > > No, no tunable for fillnodata, and it doesn't support
> > > > > multi-threaded parallelization.
> > > > > > I will use warp and the raster calculator in the future so you
> > > > > > have more magic up your sleeve, I would appreciate it.
> > > > > > Cheers and thanks again.
> > > > > > www.archeotec.ca
> > > > > > On Jun 5, 2015 19:13, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > > > > > > Le samedi 06 juin 2015 00:18:45, Nicolas Cadieux a écrit :
> > > > > > > > Hi,
> > > > > > > > I have been using gdal_grid to interpolate LiDAR data for
> > > > > > > > some time now. This would be a typical command:
> > > > > > > > gdal_grid -l P0344_sol2004_XYZI_MTM8_CGVD28_150529 -txe
> > > > > > > > 348733.0 401135.0 -tye 5568587.0 5773796.0 -a
> > > > > > > > nearest:radius1=3.0:radius2=3.0:angle=0.0:nodata=0.0 -outsize
> > > > > > > > 52402.0 205209.0 -of GTiff
> > > > > > > > H:/Nicolas/pytemp/OutPut\P0344_sol2004_XYZI_MTM8_CGVD28_15052
> > > > > > > > 9. vrt
> > > > > > > > 9 .tif --confi g GDAL_NUM_THREADS ALL_CPUS
> > > > > > > > As you can see, this is a huge raster and the csv. file
> > > > > > > > (Pointed with a .vrt) contains over a billion points.  I am
> > > > > > > > trying to do this in one shot to avoid boundary effects.  (I
> > > > > > > > know I can split this .csv file into smaller bits and make
> > > > > > > > this more efficient). The computer I am using has 12 cores,
> > > > > > > > 64BG of memory (smaller than the csv file) and a 1TB pcie
> > > > > > > > solid state drive.  It should manage the task but it has been
> > > > > > > > running for 5 days with less than 10% done).  I have access
> > > > > > > > to a super computer with gdal if all else fails.
> > > > > > > > This is my question.  The "--config GDAL_NUM_THREADS
> > > > > > > > ALL_CPUS" or "--config GDAL_NUM_THREADS 12" does not seem to
> > > > > > > > work with the nearest neighbor algorithm. (It seem to work
> > > > > > > > with the -a count command)  If I use this on a smaller data
> > > > > > > > set, I see no difference in speed or cpu usage between using
> > > > > > > > the "ALL_CPUS" or not using this switch.  Is this a bug or
> > > > > > > > simply a limitation of the nearest neighbor algorithm?
> > > > > > > Nicolas,
> > > > > > > The threading mechanism is generic for all algorithms . Add
> > > > > > > "--debug on" and you should see traces like "GDAL_GRID: Using
> > > > > > > 12 threads". Now, a reason for it not being efficient is that
> > > > > > > the work buffer used by gdalgrid (16 MB) is too small w.r.t to
> > > > > > > nearest speed. Hum, actually looking more closely at the code,
> > > > > > > I see that the quad tree to index the points will be rebuilt
> > > > > > > for each work buffer. This is likely the main cause of the
> > > > > > > inefficiency and why you don't see measurable differences
> > > > > > > between non threaded or threaded computations (since the
> > > > > > > building of the quadtree is not multithreaded). If you
> > > > > > > compiled from source, you could try changing the "const
> > > > > > > GUInt32 nDesiredBufferSize = 16*1024*1024;" line in
> > > > > > > apps/gdal_grid.cpp to a much higher value. A more proper
> > > > > > > solution would be to avoid rebuilding the quad tree for each
> > > > > > > work buffer. This is mainly code restructuring.
> > > > > > > An alternative to gdal_grid would be to use gdal_rasterize +
> > > > > > > gdal_fillnodata. This is usually much much faster, so you could
> > > > > > > try to check if it gives the results you expect.
> > > > > > > You could also try scipy :
> > > > > > > http://docs.scipy.org/doc/scipy-0.14.0/reference/generated/scip
> > > > > > > y. inte rpol ate.griddata.html#scipy.interpolate.griddata Not
> > > > > > > sure how it behaves with that number of points.
> > > > > > > Even
> > > > > > > > I don't want to move this
> > > > > > > > to a super computer if it will not multi-thread properly.
> > > > > > > > Thanks,
> > > > > > > > Nicolas Cadieux
> > > > > > > > (Gdal1.11.2 downloaded with OSGEO4W 64bit install with QGIS
> > > > > > > > 2.8 on windows 7_64)  I use GDAL from the command line not
> > > > > > > > from QGIS.
> > > > > > > > www.archeotec.ca
> > > > > > > > _______________________________________________
> > > > > > > > gdal-dev mailing list
> > > > > > > > gdal-dev at lists.osgeo.org
> > > > > > > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
