[gdal-dev] Set/Get Scale and Offset in GDALRasterBand
Alexander Bobkov alexander.e.bobkov at gmail.com
Mon Jun 22 07:50:33 PDT 2015
What is the intended usage of methods
SetScale/GetScale/SetOffset/GetOffset of the GDALRasterBand class?
Documentation says that
> This value (in combination with the GetOffset()
> <http://www.gdal.org/classGDALRasterBand.html#ab62e0761dde3e3b76f83155920275e4f>
> value) is used to transform raw pixel values into the units returned
> by GetUnits(). For example this might be used to store elevations in
> GUInt16 bands with a precision of 0.1, and starting from -100.
> Units value = (raw value * scale) + offset
Who is responsible for applying the formula: client code before/after
RasterIO operation, or driver code inside IReadBlock/IWriteBlock methods?
Best regards,
Alexander Bobkov
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150622/f66b7056/attachment.html>
