[gdal-dev] Building GDAL 2.0.0 without ogr on Linux fails
Even Rouault
even.rouault at spatialys.com
Tue Jun 23 09:14:19 PDT 2015
Kor,
I'm half surprised this ended up being broken. At the time of
https://trac.osgeo.org/gdal/wiki/rfc46_gdal_ogr_unification, it still worked
apparently but I might have accidentaly broken it later.
Anyway I was wondering if it was worth fixing that? as it might be a continuing
maintenance pain... This was something I actually considered during RFC 46 (I
mean dropping support for --without-ogr).
Even
> Dear all,
> I may have found an issue in the build scripts of gdal 2.0.0. Building
> gdal without ogr on Linux fails on my machine:
> ./configure --without-ogr
> make -j8
> I attached the output of configure and copied the snippets from the
> build output detailing the errors below.
> When I change --without-ogr into --with-ogr, the build succeeds.
> Maybe something OGR-ish is building while it shouldn't(?).
> Best regards,
> Kor de Jong
> libtool: compile: /opt/gcc-4.9/bin/g++ -I/tmp/blah/gdal-2.0.0/port
> -I/tmp/blah/gdal-2.0.0/gcore -I/tmp/blah/gdal-2.0.0/alg
> -I/tmp/blah/gdal-2.0.0/ogr -I/tmp/blah/gdal-2.0.0/ogr/ogrsf_frmts -g -O2
> -Wall -I/tmp/blah/gdal-2.0.0/port -I/usr/include -DGDAL_COMPILATION -c
> mffdataset.cpp -o ../o/mffdataset.o >/dev/null 2>&1
> ogrutils.cpp: In function ‘int OGRGeneralCmdLineProcessor(int, char***,
> int)’:
> ogrutils.cpp:526:60: error: ‘GDAL_OF_VECTOR’ was not declared in this scope
> return GDALGeneralCmdLineProcessor( nArgc, ppapszArgv,
> GDAL_OF_VECTOR );
> ogrutils.cpp:526:75: error: ‘GDALGeneralCmdLineProcessor’ was not
> GDAL_OF_VECTOR );
> ogrutils.cpp:527:1: warning: control reaches end of non-void function
> [-Wreturn-type]
> make[1]: *** [ogrutils.lo] Error 1
> make[1]: *** Waiting for unfinished jobs....
> pdfwritabledataset.cpp: In member function ‘virtual OGRErr
> PDFWritableVectorDataset::SyncToDisk()’:
> pdfwritabledataset.cpp:307:17: error: ‘class GDALPDFWriter’ has no
> member named ‘WriteOGRLayer’
> oWriter.WriteOGRLayer((OGRDataSourceH)this,
> make[2]: *** [../o/pdfwritabledataset.lo] Error 1
> make[2]: *** Waiting for unfinished jobs....
> make[1]: *** [pdf-install-obj] Error 2
> make: *** [frmts-target] Error 2
http://www.spatialys.com
