[gdal-dev] Getting warning when opening NetCDF file using gdal?
oz ljvillarin30 at gmail.com
Mon Jun 29 19:48:39 PDT 2015
I am using windows 7(32-bit) and want to warp NetCDF (nc) files and save the
output as GeoTIFF.
First I run gdalinfo first to get the info of the subdataset I need and
added NeTCDF in the beginning(e.g. gdalinfo
NETCDF:"A2015069035500.L2_LAC_OC.nc") but was unfortunate because a warning
appeared:
Warning 1: Variable has 0 dimension(s) - not supported.
gdalinfo failed - unable to open 'netCDF:A2015069035500.L2_LAC_OC.nc'.
Command line input:
gdalinfo A2015069035500.L2_LAC_OC.nc
NetCDF is present when I tried `gdalinfo --formats`.
Does anyone have any idea about this?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Getting-warning-when-opening-NetCDF-file-using-gdal-tp5213484.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
