[gdal-dev] gdaldem hillshade returns an empty .tif (i.e. everything is 181 (?))
Even Rouault even.rouault at spatialys.com
Tue Jun 30 02:41:51 PDT 2015
Le mardi 30 juin 2015 01:20:13, Ruth Simm a écrit :
> I ran this command on a completely NORMAL (but large) global .tiff with a
> few tiles missing - but nothing else suspicious - and after 40 minutes it
> returned a dud file with '181' being the only value. Has this ever
> happened to anyone before?
> gdaldem hillshade -of GTiff infile.tif hillshd.tif
Ruth,
I guess this might be an issue with the ratio of vertical units to horizontal.
http://gdal.org/gdaldem.html#gdaldem_hillshade:
-s scale:
ratio of vertical units to horizontal. If the horizontal unit of the source
DEM is degrees (e.g Lat/Long WGS84 projection), you can use scale=111120 if
the vertical units are meters (or scale=370400 if they are in feet)
I'd suggest you experiment a bit on a subwindow of your big raster or a
subsampled version of it first.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150630/6611b889/attachment.html>
