[gdal-dev] Extent of a Layer
    Even Rouault
    even.rouault at spatialys.com
    Tue Jun 30 03:19:34 PDT 2015
Le mardi 30 juin 2015 12:10:39, Ari Jolma a écrit :
> I wonder when the GetExtent method of a layer started to return an
> Envelope - at least in the Perl bindings.
> I'm quite certain that previously GetExtent method of Layer returned
> (Xmin,Ymin,Xmax,Ymax) and GetEnvelope of Geometry returned
> (Xmin,Xmax,Ymin,Ymax). Now they both return (Xmin,Xmax,Ymin,Ymax).
> I've always noted the difference in the Perl bindings documentation and
> I have code that expects GetExtent to return (Xmin,Ymin,Xmax,Ymax).
AFAIK OGR_L_GetExtent() has always returned a OGREnvelope, so the order should
have always been (Xmin,Xmax,Ymin,Ymax), unless something reordered it in the
Perl bindings.
> However, I don't find any change like this happening in the repository.
> Strange.
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
