[gdal-dev] Getting warning when opening NetCDF file using gdal?
Joaquim Luis
jluis at ualg.pt
Tue Jun 30 03:21:52 PDT 2015
I've not yet found time to upgrade to new flavor of Ocean Color nc files
but if you are using the old nc format you may find Mirone extremely
useful for this kind of manipulations.
Have a look at this 2 short tutorials
https://sites.google.com/site/mironehowtos/satellite/import-a-modis-l2-sst-hdf-grid
http://w3.ualg.pt/~jluis/mirone/howtos/Make_a_stack_of_L2_MODIS_files.html
Joaquim
> I am using windows 7(32-bit) and want to warp NetCDF (nc) files and save
> the
> output as GeoTIFF.
> First I run gdalinfo first to get the info of the subdataset I need and
> added NeTCDF in the beginning(e.g. gdalinfo
> NETCDF:"A2015069035500.L2_LAC_OC.nc") but was unfortunate because a
> warning
> appeared:
> Warning 1: Variable has 0 dimension(s) - not supported.
> gdalinfo failed - unable to open 'netCDF:A2015069035500.L2_LAC_OC.nc'.
> Command line input:
> gdalinfo A2015069035500.L2_LAC_OC.nc
> NetCDF is present when I tried `gdalinfo --formats`.
> Does anyone have any idea about this?
> http://osgeo-org.1560.x6.nabble.com/Getting-warning-when-opening-NetCDF-file-using-gdal-tp5213484.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
