[gdal-dev] reprojection issue
Robert Oehler
robert at roproducts.de
Mon Mar 2 08:01:10 PST 2015
I’m developing a raster library using GDAL. I use the Java bindings.
I would like to do a reprojection of an image which I have in memory.
I’m using an in-memory driver to create a dataset. I fill it with the properties of the image and its data.
Now I’m doing
Dataset warped = gdal.AutoCreateWarpedVRT(ds, src_proj.ExportToWkt(), dst_proj.ExportToWkt());
but the resulting raster is very different from the original. (720,720 --> 635,810) while the resulting bounding box is correct (compared to my own reprojection implementation)
What am I doing wrong?
I’ve seen gdal.reprojectImage(..) What is the difference? Is it preferable in my case ?
Thank you
Robert Oehler
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150302/b4a094ac/attachment.html>
