[gdal-dev] gdal trunk compatibility
Vincent Schut
schut at sarvision.nl
Tue Mar 3 01:33:53 PST 2015
On 03/03/15 10:26, Even Rouault wrote:
> Le mardi 03 mars 2015 10:06:51, Vincent Schut a écrit :
>> Hi folks,
>> I'd like to revive this thread a bit, because I'm trying to compile
>> rsgislib (https://bitbucket.org/petebunting/rsgislib, a c++ rs/gis library
>> which links with gdal) against my trunk version of gdal 2.0, which does
>> not work. It does work with gdal 1.x, though. I'd like to get your opinion
>> whether this is something that should be dealt with in rsgislib, or if it
>> is seen as an unwanted incompatability between gdal 1.x and 2.x, and
>> should be fixed in gdal.
> Vincent,
> Those are intented changes. They are adressed by
> http://svn.osgeo.org/gdal/trunk/gdal/MIGRATION_GUIDE.TXT (RFC 46)
> Even
Thanks Even for that link!
Vincent.
>> Initially I get the following error:
>> [ 21%] Building CXX object
>> src/CMakeFiles/rsgis_geom.dir/geom/RSGISGeomTestExport.cpp.o
>> /usr/local/src/rsgislib/src/geom/RSGISGeomTestExport.cpp: In member
>> function ‘void
>> rsgis::geom::RSGISGeomTestExport::exportGEOSPolygons2SHP(std::string,
>> bool, std::list<geos::geom::Polygon*>*)’:
>> /usr/local/src/rsgislib/src/geom/RSGISGeomTestExport.cpp:291:87: error:
>> invalid conversion from ‘GDALDriver*’ to ‘OGRSFDriver*’ [-fpermissive]
>> shpFiledriver =
>> OGRSFDriverRegistrar::GetRegistrar()->GetDriverByName(pszDriverName ); ^
>> function ‘void
>> bool, std::vector<geos::geom::Polygon*>*)’:
>> /usr/local/src/rsgislib/src/geom/RSGISGeomTestExport.cpp:364:87: error:
>> shpFiledriver =
>> function ‘void
>> rsgis::geom::RSGISGeomTestExport::exportGEOSCoordinates2SHP(std::string,
>> bool, std::vector<geos::geom::Coordinate*>*)’:
>> /usr/local/src/rsgislib/src/geom/RSGISGeomTestExport.cpp:437:87: error:
>> shpFiledriver =
>> function ‘void
>> rsgis::geom::RSGISGeomTestExport::exportGEOSLineStrings2SHP(std::string,
>> bool, std::vector<geos::geom::LineString*>*)’:
>> /usr/local/src/rsgislib/src/geom/RSGISGeomTestExport.cpp:510:87: error:
>> shpFiledriver =
>> function ‘void
>> rsgis::geom::RSGISGeomTestExport::exportGEOSLineSegments2SHP(std::string,
>> bool, std::vector<geos::geom::LineSegment*>*)’:
>> /usr/local/src/rsgislib/src/geom/RSGISGeomTestExport.cpp:584:87: error:
>> shpFiledriver =
>> src/CMakeFiles/rsgis_geom.dir/build.make:169: recipe for target
>> 'src/CMakeFiles/rsgis_geom.dir/geom/RSGISGeomTestExport.cpp.o' failed
>> make[2]: ***
>> [src/CMakeFiles/rsgis_geom.dir/geom/RSGISGeomTestExport.cpp.o] Error 1
>> CMakeFiles/Makefile2:487: recipe for target
>> 'src/CMakeFiles/rsgis_geom.dir/all' failed make[1]: ***
>> [src/CMakeFiles/rsgis_geom.dir/all] Error 2
>> If I rebuild with -fpermissive, compilation continues a bit further, but
>> then halts here:
>> [ 65%] Building CXX object
>> src/CMakeFiles/rsgis_classify.dir/classifier/RSGISClassificationUtils.cpp.
>> o /usr/local/src/rsgislib/src/classifier/RSGISClassificationUtils.cpp: In
>> member function ‘void
>> rsgis::classifier::RSGISClassificationUtils::convertShapeFile2SpecLib(std:
>> :string, std::string, std::string, std::vector<std::basic_string<char> >*,
>> bool)’:
>> /usr/local/src/rsgislib/src/classifier/RSGISClassificationUtils.cpp:174:17
>> : error: ‘Open’ is not a member of ‘OGRSFDriverRegistrar’ inputSHPDS =
>> OGRSFDriverRegistrar::Open(vector.c_str(), FALSE); ^
>> src/CMakeFiles/rsgis_classify.dir/build.make:77: recipe for target
>> 'src/CMakeFiles/rsgis_classify.dir/classifier/RSGISClassificationUtils.cpp
>> .o' failed make[2]: ***
>> [src/CMakeFiles/rsgis_classify.dir/classifier/RSGISClassificationUtils.cpp
>> .o] Error 1 CMakeFiles/Makefile2:290: recipe for target
>> 'src/CMakeFiles/rsgis_classify.dir/all' failed make[1]: ***
>> [src/CMakeFiles/rsgis_classify.dir/all] Error 2
>> This is clearly a compatibiliby issue with the new gdal 2.0 raster/vector
>> unification. Question is: is this something that should be fixed within
>> gdal, or should it be changed in rsgislib?
>> Thanks for your insights!
>> Vincent.
>> On 12/16/14 11:27, Even Rouault wrote:
>>> Le mardi 16 décembre 2014 11:06:14, Vincent Schut a écrit :
>>>> Folks,
>>>> I'd like to use gdal-trunk (e.g. 2.0) for all the new features and
>>>> improvements, but I wonder about its compatibility with other software.
>>>> Is gdal 2.0 supposed to work transparently with libraries/programs that
>>>> used to link against gdal 1.11, e.g. qgis, postgis, etc.?
>>> Vincent,
>>> They mostly work unmodified, although you could run into a few problems
>>> if opening a dataset with curve geometries in QGIS for example (but
>>> there be some work to use OGR curve geometries in QGIS soon)
>>>> Reason I ask is I get a configure error with postgis trying to find
>>>> gdal:
>>>> RASTER: Raster support requested
>>>> checking for gdal-config... /usr/local/bin/gdal-config
>>>> checking GDAL version... 2.0.0
>>>> checking for OGR enabled... yes
>>>> checking gdal.h usability... yes
>>>> checking gdal.h presence... yes
>>>> checking for gdal.h... yes
>>>> checking ogr_api.h usability... yes
>>>> checking ogr_api.h presence... yes
>>>> checking for ogr_api.h... yes
>>>> checking cpl_conv.h usability... yes
>>>> checking cpl_conv.h presence... yes
>>>> checking for cpl_conv.h... yes
>>>> checking for library containing GDALAllRegister... no
>>>> configure: error: could not find GDAL
>>>> the last line ("checking for library containing GDALAllRegister...")
>>>> takes a long time and then fails...
>>> I know PostGIS has a continuous testing system tracking GDAL trunk, so
>>> I'd say the issue is more on your side. GDALAllRegister is definitely a
>>> symbol that still exists in GDAL 2.0dev
>>> http://debbie.postgis.net:8080/job/GDAL_PostGIS_Regress/2074/consoleFull
>>> Even
>>>> Thanks,
>>>> Vincent.
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
