[gdal-dev] Default progression order in JP2OpenJPEG driver
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Thu Mar 5 22:07:12 PST 2015
Even Rouault <even.rouault <at> spatialys.com> writes:
> When reading with an efficient JPEG2000 decoder, for the same block size, I
> can't see any really noticeable difference between the 3 profiles, either
when
> reading a single pixel, random regions at full resolution, or a downsampled
> region. I presume the difference between the organizations would appear in
> network streaming contexts rather than with an efficient storage and reader.
Now once you say it I remember why I had a feeling of LRCP being so poor. It
was based an my tests I made a long time ago about serving images for
on-screen browsing through JPIP by using a dial-up modem and speed throttled
to 4 kbps. Very different use case indeed.
-Jukka-
