[gdal-dev] Default progression order in JP2OpenJPEG driver
Even Rouault
even.rouault at spatialys.com
Fri Mar 6 04:06:13 PST 2015
> Besides multiple quality layers, I'm wondering about additional benefits
> from configurable Tile Parts indexes (-TP param, helps with browsing and
> ROI retrieval when R- or P-indexed), as well as optional small code blocks
> (-b param, e.g. 32² instead of the default 64², allowing for fine-grained
> ROI retrieval).
I've extended the QUALITY option to specify several values (and thus layers).
And added TILEPARTS, CODEBLOCK_WIDTH and CODEBLOCK_HEIGHT options.
> Cheers
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
