[gdal-dev] GNM Usage
Mikhail Gusev
gusevmihs at gmail.com
Wed Mar 11 04:08:54 PDT 2015
No, it will not break the line into segments. All point features that are
geometrically on the line feature except endings will be ignored.
For Y intersection the connections will be created only for 3 lines with
the common end point.
2015-03-11 14:28 GMT+04:00 ChiefDan <ChiefDan at gmail.com>:
> Thanks for the response. The source data is in EPSG 900913, the network
> data
> according to ogrinfo:
> PROJCS["WGS_84_Pseudo_Mercator",
> GEOGCS["GCS_WGS_1984",
> DATUM["WGS_1984",
> SPHEROID["WGS_84",6378137,298.257223563]],
> PRIMEM["Greenwich",0],
> UNIT["Degree",0.017453292519943295]],
> PROJECTION["Mercator_1SP"],
> PARAMETER["central_meridian",0],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0],
> UNIT["Meter",1],
> PARAMETER["latitude_of_origin",0.0]]
> Looking at the individual point values, they seem to be EPSG 4326:
> OGRFeature(gnm_Frog_Branches_point):1
> name (String) = 78B-S-0
> gfid (Integer) = 68
> POINT (12.305749698885625 45.450093091932679)
> For a line with multiple point objects on it, will the GNM processing break
> the line up into multiple segments creating the line segments between the
> points?
> Also, if there are overlapping lines that form a Y intersection, can the
> GNM
> processing recognize that as a potential path?
> http://osgeo-org.1560.x6.nabble.com/GNM-Usage-tp5192401p5192757.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150311/72e9a6a0/attachment-0001.html>
