[gdal-dev] can't compile gdal-grass plugin against GRASS 7
Donovan Cameron
sault.don at gmail.com
Wed Mar 11 09:58:09 PDT 2015
Thanks a lot Martin,
build worked great, just had to patch the resultant Makefile because...
make DESTDIR="${pkgdir}" install
...would fail because the DESTDIR var wasn't recognized in the Makefile,
which I patched in.
But that's a limited use case and likely not applicable to anyone who
isn't running Arch Linux and using makepkg.
Donovan
On 10/03/15 05:28 PM, Martin Landa wrote:
> Hi,
> 2015-03-11 1:15 GMT+01:00 Saulteau Don <sault.don at gmail.com>:
>> That's good news. Thanks Martin.
>> I'd like to test 1.11.3 so it'd be great if I could get a copy of it.
> please try out [1].
> Martin
> [1] http://geo102.fsv.cvut.cz/~landa/tmp/gdal-grass-1.11.2.tar.gz
