[gdal-dev] OpenFileGDB, feature classes in feature dataset
Armin Burger armin.burger at gmx.net
Sat Mar 14 07:30:13 PDT 2015
Hi Even
thanks for the reply!
The FGDB dataset where I discovered that has unfortunately some
commercial IPR restrictions, so I cannot share it (and it in addition
has some 800 MB...). I will try to create a test FGDB with a similar
internal structure, I have to check if I can create an FGDB v9 format
with recent ArcGIS versions.
Armin
On 03/10/2015 06:48 AM, Even Rouault wrote:
> Selon Armin Burger <armin.burger at gmx.net>:
>> Dear all
>> I have a question regarding the OpenFileGDB driver in 1.11.2 release. It
>> now lists also non-spatial tables as layers of an FGDB (as mentioned in
>> the changelog). But it seems to not list any more layers that are
>> "feature classes" under a parent "feature dataset" (that's how the
>> relation is displayed in ArcGIS). This is at least the case for FGDB's
>> in older v9 format. In GDAL version 1.11.0 these feature classes were
>> still listed as layers.
>> Is this a bug or an intended behavior?
> Looks like an unfortunate side effect. could you open a ticket and attach such a
> GDB or provide a link to it ?
>> Best regards
>> Armin
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
