[gdal-dev] gdal_translate with -projwin SOLVED
Even Rouault even.rouault at spatialys.com
Mon Mar 16 09:06:32 PDT 2015
Selon Zoltan Szecsei <zoltans at geograph.co.za>:
> OK, it was simple.
> I did not have permission to write to the output directory !!!
Ah, I imagined that it could have been a reason but didn't mentionned it because
I was convinced you would have gotten an explicit error message. In fact, this
was a trunk regression specific to the GTiff driver. Now fixed (and unit test
checked)
http://www.spatialys.com
