[gdal-dev] Add source no-data masking to proximity computation
Daniel Evans dan at rekt.io
Tue Mar 17 13:32:30 PDT 2015
Hello,
I recently submitted a pull request against GDAL that adds an option that
causes GDALComputeProximity to take into account areas of no data within
the input raster and updates gdal_proximity.py with a -use_nodata flag.
This pull request is here https://github.com/OSGeo/gdal/pull/49
Is this likely to be accepted? It saves a processing step to re-add no data
areas when working with certain tools. Do any changes need to be made
elsewhere?
Thanks,
Daniel.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150317/7753b50f/attachment.html>
